Old 09-13-2009, 08:24 PM   #16
Integra's Avatar
Originally Posted by reggie l. View Post
it all depends on how u treat the motors in general will determine if it will loose pinch or not...
X2....OS make's awesome motor's...but if treated improperly you WILL pay for it down the road.
Old 09-13-2009, 08:39 PM   #17
Originally Posted by quicklosi View Post
i have the ninja bo1a with the lightened head. got a little ever a gallon on it right now. no way i can turn the flywheel over by hand as it sits in the car. need it out to turn it over by being able to grab the flywheel this motor has MAD compression. after a gallon of fuel and starting to lean it out i am SCREAMING around the track getting a little over 9min on a tank and running temps right around 230. this is all in a Mugen MBX6 and i love it
BEST MOTOR I HAVE EVER OWNED
Same as me but in a D8.
quicklosi- what fuel are you running?
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 09-13-2009, 08:53 PM   #18
Don't worry about being able to turn it over by hand or not. I can turn mine over by hand when in the car cold frm he flywheel at 1 gallon, but I still have some mechanical pinch when cold and the plug is out. It runs 9:30-10:00 @220 with a ton of power, and that is with the 7mm in. I need to throw a 6.5 or 6.0 in it to see what happens.
If it is running strong, idles well and has good smoke then you are allright. The hottest my engine has ever been is 261 and that was after a 20 min main last night, hotter then I want but it will not hurt anything. If you get into the 275-300 range you are risking damage. Most O.S. engines I have ever messed with (a LOT of them at my track) do not hold their compression like a Nova does. They still run well though.....
USP45 is offline   Reply With Quote
Old 09-13-2009, 09:55 PM   #19
wfo
wfo's Avatar
Originally Posted by dreaux View Post
I have over a gallon in it and it will barely get warm. Is it the 20% should i take a shim out?
Dont be scaaared to put some heat into it. i would just run it w/ stock shims or take out the smallest one later on...my 1 st ninja really came alive about 1 1/2 gallons into it... i run all 3 shims w/ 30% my friend has my 1 st one in his mbx6T and the
ninja throws that thing around like a rag doll.....
wfo is offline   Reply With Quote
Old 09-14-2009, 01:18 AM   #20
I am running Byrons GEN 2 30% with the 3 shoe aluminum clutch and 1.0 springs and the P3 for the plug. temps were hot this past weekend (104 on race day sat) and i tried a P4 but the motor just didnt like it too much so i went back with the P3
quicklosi is offline   Reply With Quote
Old 09-14-2009, 03:02 AM   #21
How is break-in engine best?
AK_Nguyen is offline   Reply With Quote
Old 09-14-2009, 05:40 PM   #22
i finally quit using the heat gun to start my motor and it gets hotter on it's own and runs better. go figure.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 09-14-2009, 07:04 PM   #23
how do you figure it runs better without the heat from a heat gun? all the use of a heat gun does is allows the sleeve to expand before the initial start of the motor allowing for less stress on the CONROD. until i have about 3+ gallons on my ninja i will continue to use the heat gun. it is also smart to not start tuning an engine until the motor and chassis are completely up to temp so again here using a heat gun allows you to get to this process faster.
just my .02
Old 09-14-2009, 10:41 PM   #24
Hmm, we're running the same set up and got the same results. That's interesting.
Old 09-15-2009, 09:10 AM   #25
that sounds like consistency of a bad ass motor
Old 09-15-2009, 11:09 AM   #26
shady3031's Avatar
Trader Rating: 26 (100%+)
It didn't have anything to do with the heat gun, I use one of the engine warmers that mark at powerhouse sells. Use it everytime I start any motor no matter how many gallons are on the motor. Used it this weekend to start my jx that has just over a gallon of sidewinder worlds 30 on it and the motor ran great its in a 2.0T ran a 20 min main pitted once on a med to tight track and it came of just over 220 and its a little rich on the top and little lean on the mid-Its got the eb button and I am imprrssed so far and that's with an 8mm stack
The Warehouse RC-Birmingham, AL
AE RC8.2-E Tekin powered
Alabama Manufacturers Shootout-Don't Miss It
shady3031 is offline   Reply With Quote
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
how long in general does it take for a motor to lose it's metal pinch? dreaux Nitro Off-Road 10 08-25-2009 08:21 PM
~~~~.21 Engines/pipes For Sale - GRP, Ninja, O.S.~~~~ jaylude22 R/C Items: For Sale/Trade 21 03-29-2009 10:39 PM
ninja jx .21 help plz downunder23 Nitro Off-Road 20 02-19-2009 01:00 AM
New ninja 12 wont fire!! Jason Smith Nitro On-Road 58 09-14-2007 05:18 AM
