Dirt in Screws
i got a set of picks from walmart
or use an x-acto
or use an x-acto
Air Compressor set at 175psi.
I use a small screw driver that comes to a point, not sure what its called but it works with out causing damage to the screw im tring to get out.
One thing you can do before using the pointed tip is to take a wet rag and wipe the exposed surface of the screw head. The dirt soaks up the water in the rag and it makes the dirt even easier to clean out.
if you pick up a 4 pack up picks at wal-mart you will be surprised how many things you can find to use them for. They make easy work of a lot of RC task.
wrist pin clip removal, e-clip removal, exhaust springs, dirt removal to name a few.
the 4 pack has 1 straight, 1 90 degree, 1 hook and 1 squiggly.
I use the "scraper" thingie that a dentest uses to clean your teeth.
