Old 09-13-2009, 09:43 AM   #1
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
Default When to replace a chassis?
I have a RC8 that has about a year or so on the chassis, but not sure if it is ready to be replaced. It has its wear marks on the bottom but not bent. Im going thru the car and replacing all my worn out parts and kinda doing an update to match the RC8B mainly the towers and radio tray and the hinge pin plates. Whats yall's opinion?
Lance Plant
Sponsors: Team Associated~Reedy~LRP~Pro Line~Avid RC~Airtronics~Werks Racing
TXRC8racer is offline   Reply With Quote
Old 09-13-2009, 10:05 AM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
I dont know the exact critical point of when necssary but have seen fully sponsered losi drivers with stock 2.0 chassis that are compltely silver on the bottom, not hardly 1 speck of black and the top looks new
Mark Buecker
8&stuff is offline   Reply With Quote
Old 09-13-2009, 10:34 AM   #3
E-Dog's Avatar
I don't pay attention to how many scratches it has on the bottom, as the other person said some sponsered drivers drive them like that.
What I would do is tear down the buggy until you have the bear chassis, then place it on a flat surface to make sure it isn't tweaked (bent, cracked etc...), then I will look at the Down stops (Droop points) and make sure there is still reasonable material left for it to work properly. if not then replace, if your chassis is still reasonable then Roost-on
E-Dog is offline   Reply With Quote
Old 09-13-2009, 12:05 PM   #4
TXRC8racer's Avatar
Thanks for the input!!!
The chassis is not completly silver on the bottom mainly on the kickup points of the chassis. So i will run it a little longer prolly untill the first of the next year.
Lance Plant
Old 09-13-2009, 12:48 PM   #5
Racecrafter's Avatar
Trader Rating: 25 (96%+)
We run chassis' until the back is thin. Generally to about 1.5mm unless as menioned that during a rebuild you find that it's bent or the droop screw areas are deeply worn.
Jimmy Wright
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-13-2009, 03:42 PM   #6
TXRC8racer's Avatar
Is the chassis suppose to have a bow in it to help for flex? I checked mine on a flat surface and it has a slight bow up in the middle,is this normal?
Lance Plant
Old 09-13-2009, 04:07 PM   #7
Integra's Avatar
i know the losi isn't 100% flat from factory...but the RC8 im not too sure.
Old 09-13-2009, 04:10 PM   #8
Sounds like it's time for replacement....
Jimmy Wright
Old 09-14-2009, 06:44 AM   #9
TXRC8racer's Avatar
I figured it came like that for flex..but maybe not..
Lance Plant
Old 09-14-2009, 06:57 AM   #10
Depends, I will change my chassis at the end of the season - if I plan on keeping the chassis for the next season. i personally just think that these 1/8 go through a lot of abuse and I just think that all the pressure and stress that is put on the chassis, it becomes weaker.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-14-2009, 12:46 PM   #11
PTP Racing's Avatar
The chassis should be flat but a little bow from front to rear isnt gonna make a huge difference but if it twists your going to probably have some issues.
I ran my last RC8 chassis down to 1mm in the rear and replaced it. I bought a rtr chassis for $45 but next time I think I am gonna get a BCE chassis because I have been told they last a lot longer.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 09-14-2009, 01:26 PM   #12
Integra's Avatar
guys there called Skid plate's ....replacing a chassis every season is imo overkill and not needed.
Old 09-14-2009, 01:57 PM   #13
PTP Racing's Avatar
I refuse to use a skid plate. I think they screw the cars handling up. Every time I see a car bucking really bad in back they are running a skid plate.
Jason Miller
Old 09-14-2009, 02:09 PM   #14
losi_racer's Avatar
Trader Rating: 25 (100%+)
HA!, dont believe everything you hear. if i was keeping my buggy i would be going back to stock, That thing has more time on it then the bce and bce has twice the wear
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-14-2009, 02:13 PM   #15
Trader Rating: 34 (100%+)
just curious as of to the reason behind this?
Smith90 is offline   Reply With Quote
Help me choose a chassis! noelcleofe17 Electric On-Road 19 08-10-2009 07:56 AM
Anybody go to east coast track before? Mr.chicky Singapore R/C Racers 180 01-21-2009 08:43 PM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 09:50 PM
ROAR goes to 4cell... What will tracks do? peter_robinson Northwest Racers 76 12-02-2006 11:27 AM
Recommend a good raceable 1/10th Nitro car nikkor Singapore R/C Racers 22 09-25-2005 11:59 AM
