Old 09-12-2009, 09:11 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Upgrading 1.0 to 2.0
Ok guys I currently have a losi 1.0 which I want to make better overall. So ive added some 2.0 parts. So far this is what i have:
2.0 Rear Shock Tower
2.0 Front Shock Tower
2.0 Body
2.0 Radio Tray
2.0 Linkage
2.0 Steering Rack
What else do you guys recommend?
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 09-12-2009, 09:30 PM   #2
Chassis and rear driveshaft.
bigde2001 is offline   Reply With Quote
Old 09-12-2009, 09:31 PM   #3
jhipps835's Avatar
Oh yea I will be saving for that. Anything else?
Old 09-13-2009, 04:05 AM   #4
MaTt 93's Avatar
Send a message via MSN to MaTt 93
Umm you could add the center smart diff
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 09-13-2009, 07:36 AM   #5
jhipps835's Avatar
I thought that was an option part. Does the 2.0 come with the center diff? Anything else?
Old 09-13-2009, 07:56 AM   #6
Trader Rating: 29 (100%+)
no its an option part. but its a great part to have!
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 09-13-2009, 07:58 AM   #7
a couple more little things are like the arms(they are slightly longer), spindles, spindle carriers, fuel tank(only difference is its sure close with 2 springs)
theres a couple more minor things.
Old 09-13-2009, 08:00 AM   #8
jhipps835's Avatar
Ok. Ill look into those.
Old 09-13-2009, 08:02 AM   #9
and also if you were gonna end up getting the 2.0 chassis, id say look into the BCE 2.0 chassis. its not made by losi but i hear its better than losi's 2.0 chassis. there is a forum on here for their product and reviews on there.
Old 09-13-2009, 08:28 AM   #10
Frank L's Avatar
Trader Rating: 148 (100%+)
I thought the spindles and spindle carriers were the same onthe 2.0 & 1.0.
As for the chassis check out bce they have an awesome chassis. If I was to do anything all I would do is buy a bce chassis and 2.0 rear drive shaft. Run the rest. I know a guy that did the chassis upgrade to his 1.0 and it bade a huge improvement.
Old 09-13-2009, 08:32 AM   #11
smittyusmc's Avatar
When you get the 2.0 chassis make sure that you get the drop srews that go into the chassis you will need them. When I bought my chassis I did not no I needed them and it made my droop way off.
Hot Bodies Hara D8 - ODss .21
Team Associated B4.1 reedy 8.5, R10 Pro
Team Associated T4.1 OHP 17.5, Tekin RS
Team Associated B44.1 reedy 6.5, R10 Pro
smittyusmc is offline   Reply With Quote
Old 09-13-2009, 09:40 AM   #12
8&stuff's Avatar
Trader Rating: 55 (100%+)
8ight carriers and spindles are different than 8ight 2.0 spindles and carriers. there are a few differeances including plastics as well as geometry i believe. on the 2.0 carrier there is a half moon grub screw at location where the suspension arm attaches to the carrier.
Jhipps. I know you are wanting a 2.0 for performance as well as to be up to par with the latest equipment etc...although with the differences between the 1.0 and 2.0 you will not notice that they are much different at our level of driving. i would simply suggest to wear out the parts you have with the 1.0 and upgrade to a 2.0 complete car when the 1.0 wears out. maybe just grab a bce chassis and 2.0 towers and move on. if tuned correctly the 1.0 will perform every bit as well as a 2.0 out of the box new at our level the 1.0 race roller will be equal to the 2.0 race roller new in box. with the 8t & 8t2 they are very different with more than subtle changes.
I almost chimed in last night right after you opened the thread although i waited. im sure you already have most the stuff to convert and you will have your 2.0 built soon. most of all when completed you will have piece of mind which might make the best driver the best. good luck
Mark Buecker
8&stuff is offline   Reply With Quote
Old 09-13-2009, 09:42 AM   #13
jhipps835's Avatar
Thank you for the help.
Old 09-20-2009, 11:32 AM   #14
jhipps835's Avatar
Can someone send me a link to the driveshaft i would need if i got the 2.0 chassis. Thanks
Old 09-20-2009, 11:49 AM   #15
here you go!
http://www.horizonhobby.com/Products...rodID=LOSA3536
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
8IGHT-T 1.0 throttle/brake servo issues elkman Nitro Off-Road 9 08-10-2009 02:29 PM
Upgrading the 8ight and 8ight-T? 18ight7 Nitro Off-Road 12 06-18-2009 03:41 PM
