Old 09-12-2009, 05:53 PM   #1
GearHd6's Avatar
Questions?? Ofna Hyper .21 Mid Range Setting?
I just picked up an Ofna Hyper 7 PCR Edition with the Hyper .21 non pull start engine. I believe the Mid Range adjuster on the carb has been messed with. I notice on Ofna's website they say NOT TO ADJUST that screw and to call their tech department if it's been adjusted. Does anyone have any idea what that should be set to?
Thanks in advance!
GearHd6 is offline   Reply With Quote
Old 09-12-2009, 06:11 PM   #2
helivaguy's Avatar
Trader Rating: 42 (100%+)
here ya go..
http://www.ofna.com/forum/viewtopic.php?t=4339
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 09-12-2009, 06:14 PM   #3
Default re
carefully remove your highspeed needle assembly and fuel nipple noting where the washers are the mid range should be flush with the housing and after you remove your high speed assembly look in the hole you should see a fuel inlet hole in the nid range needle it should be dead center of the opening once you have it centered carefully replce the needle assembly being very careful not to croosthread or overtighten hope this helps
toofless is offline   Reply With Quote
Old 09-12-2009, 06:16 PM   #4
GearHd6's Avatar
WOW! Great link! Exactly what I was looking for. Thank you very much!
Hyper TQ Black eninge help please??? HaraR40 Nitro Off-Road 11 05-29-2009 02:26 PM
