Old 09-11-2009, 12:27 PM   #16
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Mine always went out about 12mins into a the main @ 130 deg on the receivers. I had 4 receivers go one right after another during test before the Nat's, 603's and 604's. After contacting Scott Cramer at Hobbico, I have had no issues. I also have the newer updated 4PK model too.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 09-11-2009, 12:28 PM   #17
Trader Rating: 24 (100%+)
I have two of these 4pk and 6 rx (603fs, 603ff and 604fs) all worked great in my electric vehicles. Then one of my friend's turned me into a nitro junk and then the issues started happening
I'll try different locations for the RX and if it fixes it then GREAT, if not then I'm going back to the DX3R.
Jody J.
JodyJ is offline   Reply With Quote
Old 09-11-2009, 12:35 PM   #18
Jody J.
What I did in my RC8B & RC8T is mount only the receiver in the the receiver box. I took 1/4" foam and raised it in the box and used double sided tape. Gluing the RX to the foam worked the best for me. Raising the RX will keep it from getting the chassis heat too. I also keep it as close to the switch as possible. I have no extra holes or foam in the box, this seemed to help out a little and get me by. I also cleared some material off the the back of my buggy body too. This will let the heat get out.
Old 09-11-2009, 01:10 PM   #19
RJNicholson's Avatar
This is exactly why I went with Spektrum.
O and the fact that right on the box it says Spektrum RX can handle 9.6v which means LiPo w/o a reg, and still no over heating issues.
*Team Terribles*
Rigs Listed Below
Losi 8IGHT 2.0 B/BCE Chassis/OS VZB *Sleeper*/RE11/JRHV Servos/KHZ
Losi 8IGHT 2.0 B/Werks B7 Pro/2013/Hitech HV Servos
Losi 8IGHT 2.0 E/Mamba Monster ESC/Xcelorin 2100kv or NEU Castle 2650kv *RIP-LIPO FIRE
RJNicholson is offline   Reply With Quote
Old 09-11-2009, 02:26 PM   #20
as they stated earlier are right ,when i encounter this before on my 3pks im really frustated imagine a pricey radio got issue ...........anyway this is what they suggest me 2 things & im all good ,1st set the fail-safe ,2nd drill some hole on your receiver box ,i believe 2 hole is fine ........................to bushyar15 ,im using the ballistic 2700 nimh pack for my rc8t (the servos are hitec 7985/7955) & no problem
team terribles
mbx5rcr34 is offline   Reply With Quote
Old 09-11-2009, 03:23 PM   #21
Trader Rating: 43 (100%+)
Originally Posted by JoeyTheRocket View Post
Mr. Cramer did take care of me though, but Futaba is on there last leg with me.
same crap happened to me in front of cramer as well with my 3pk, he gave me a new rx but same thing happened. it got sold and i went to the dx3r.
www.coyotehobbies.com-Owner
Brian Alderman is offline   Reply With Quote
Old 09-11-2009, 05:40 PM   #22
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Of course the receiver box is hot, its next to the motor. Also, if you are running a lipo with a Regulator, the regulator heats up.
I race lipo with regulators, and had a couple problems. Since then, i have removed the regulators, and not 1 problem.
Bigedmond is offline   Reply With Quote
Old 09-11-2009, 07:08 PM   #23
tristyn's Avatar
Default 2.4 heat problem
I run lipo in my truggy with reg. and I have had this happen so many times. seems to happen about 1/2 way into the main. I run a nimh 2700 balistic in buggy and have never once had this problem even when racing in 110 deg weather. If outside temperatures are 60-75 deg. I never have a problem with lipo. It is def. frustrating.
tristyn is offline   Reply With Quote
Old 09-11-2009, 07:24 PM   #24
Zerodefect's Avatar
The guys with the 4pk that I've seen, and that have had good luck, mounted the Rx upside down on the lid of the radio box and put airplane rx foam in the bottom of the box. They were running Nihm batteries. Keep in mind a regulator makes a ton of heat. Put that reg on the outside or go Nihm.
Its a shame, would be the perfect radio if it didn't overheat and costed two hundred less than it deos.
Apparently even the best pros are having this problem:
Zerodefect is offline   Reply With Quote
Old 09-12-2009, 12:52 AM   #25
Trader Rating: 36 (100%+)
I guess I should count my blessings :P. I've been running LiPo, no reg, 4PK/604FS in my Nitro Moo all summer, no problems. If I had to guess, it's likely due to no reg and maybe also in part to location, as the Rx box on the Moo is opposite the engine...
NitroOB4You is offline   Reply With Quote
Old 09-21-2009, 12:09 PM   #26
tristyn's Avatar
Default futaba
After traveling 3 hrs to go racing this last weekend it happened again. I called futaba this morning about a fix and they denied having this problem infact the guy I spoke with said he had never heard of this problem. GOODBYE FUTABA.
Old 09-21-2009, 12:16 PM   #27
JayL's Avatar
EXACTLY and yet the 'team drivers' who post claim all issues have been fixed.....
HOW CAN YOU FIX AN ISSUE THAT IS CLAIMED NEVER EXISTED??????????
JayL is offline   Reply With Quote
Old 09-21-2009, 01:53 PM   #28
Integra's Avatar
Knock on wood......I have yet to have a 603 shut down on me running Losi reg and a variety of lipo's from Protec to Losi to ebay cheepos with the reg In the box with the Rx Right beside it
OLD pics but same set-up on the 2.0's with the Reg exactly where it sits
Ace....Yuck
Old 09-21-2009, 07:31 PM   #29
Now that's funny. After drilling holes in the receiver box on the RC8t, I have not had any issuse (knock on wood)!
Have NOT done it to the RC8B yet, will drill some holes and test again on Thursday at Rev.
Thanks.
Jody J.
Old 09-21-2009, 10:05 PM   #30
jpz_67's Avatar
Trader Rating: 56 (100%+)
Thats how futaba lost my support as well.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Futaba 4pk Atom357 Radio and Electronics 1621 03-09-2017 01:15 AM
Futaba Reciever question Maxpwr Nitro Off-Road 29 08-20-2009 02:45 AM
