Old 09-12-2009, 10:16 AM   #16
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
1c, just do it like they call for it. this isnt stock ISTC. losi 2000 thru their regulator and for the races i did it was a treat. just the thought of goin that far and only issue b'g how far u went and rememberin to put it on the cooker before the next mtg.
R
UltegraSTI is offline   Reply With Quote
Old 09-13-2009, 07:31 PM   #17
madweazl's Avatar
I just discharged the 2000mah Losi pack after a full day of practice/racing. I pulled it off the charger with 2063mah and after discharge it still had 1211. I had at least 65 minutes of actual run time plus the time used in the pits adjust settings etc. It powered 2 Hitec 7950s and a transponder for 25 minutes of that. Pretty impressed with it's capacity.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 09-13-2009, 08:28 PM   #18
Integra's Avatar
Why are you 100% discharging your pack ?....after discharge it was at 1211 what ?
Old 09-13-2009, 08:37 PM   #19
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Rule 1, Dont discharge Lipos.. especially all the way.
Rule 2, After a charge, and the pack's voltage settles down, learn what a fully charged/ half charged, and a low charged lipo rx pack voltages should be at.
Rule 3, Dont discharge Lipos..
Rule 4, Dont warm lipos
Rule 5, Dont overcharge/high rate charge these little RX packs.
Rule 6, Dont discharge Lipos.
TLR ~ MaClan ~ Hobbywing ~ Futaba ~ Proline ~ Werks Racing ~ Genesis R/C Products ~ Mr. Scrubbles ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-13-2009, 09:13 PM   #20
madweazl's Avatar
I discharged to see what was left in the pack. I suppose I should have just charged it back up to see what was left but I didnt think about it at the time. There was 1211mah left in the pack after yesterdays run so I used less than have the capacity (it usually peaks around 2150-2200). It was charged at 1amp and discharged at .70; no noticeable heat on the charge or discharge cycle.
RadioPost
Old 09-13-2009, 09:20 PM   #21
Cory Kerber's Avatar
As long as the cells didn't drop below 3.2v each you should be okay. Just never discharge a lipo. If you want to check how much mah you used, just charge it.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 09-13-2009, 09:23 PM   #22
madweazl's Avatar
I didnt happen to check the cutoff voltage, I just used the discharge cycle on the Hyperion charger for 2s LiPO 2000mah; hopefully it was smarter than I was (LiPO rookie).
RadioPost
Old 09-14-2009, 07:53 AM   #23
Integra's Avatar
I can only hope so....double check what you have the discharge voltage set at.
Old 09-14-2009, 08:03 AM   #24
madweazl's Avatar
I know the defaults are usually pretty conservative with that charger. It charged fine and it hasnt puffed at all so I'm not worried about if; if the car catches fire we'll know why
RadioPost
Old 09-14-2009, 08:14 AM   #25
Do not discharge LIPOS
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
RX packs, lipo and NIMH KSimmonds R/C Items: For Sale/Trade 8 07-08-2009 02:36 PM
Losi LiPo Rx. Packs hlpressley R/C Items: For Sale/Trade 11 07-03-2009 01:20 PM
How many mah for a lipo rx pack? wstuart Nitro Off-Road 12 05-30-2008 10:22 PM
Lipo RX Packs going4#1 Nitro On-Road 15 02-12-2008 07:58 AM
lipo RX packs and spectrum Jason Halvorson Nitro Off-Road 19 01-22-2008 08:08 AM
