Old 09-10-2009, 07:04 AM   #1
zonda's Avatar
Default clutch/engine problems
ok so I ran my GO 5 port gen 4 today and i noticed it has no bottoem end at all. when I use full throttle it revs up and doesnt start screamin till mid range. It has loads of top end, crazy top end but from low end to mid theres nothing. theres plenty of smoke at full throttle. I have checked the low end and its not making that rich burbling sound and its not lean bogging. at idle you can see tiny droplets of fuel at the exhaust tip now and then. not alot though.
Im using alloy clutch shoes which i installed my self and the tips of the clutch springs are worn.
im going to try some high bite carbon shoes and new springs. I may have bent the old ones.
I hope it is the clutch because my engine seems to be runing ok apart from the powerless bottom when I hit the throttle
zonda is offline   Reply With Quote
Old 09-11-2009, 09:14 PM   #2
Pipe can affect bottom and stiffer cultch springs may help to. Hope this Helps.
bigde2001 is offline   Reply With Quote
Old 09-12-2009, 04:06 AM   #3
Trader Rating: 61 (100%+)
try a stiffer clutch set up gotech have notorious huge bottom end ...try leaning the lsn an hour at a time as well ..maybe to rich on bottom ...
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 09-12-2009, 09:05 AM   #4
Madbrad's Avatar
Trader Rating: 29 (100%+)
Is this motor fully broken in ? If not it can still be tight and just needs more run time on it.
If it is broken in , then check for worn out springs, if there engaging too soon then it will cause a to feel like there is no bottom end power.
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
ENGINE PROBLEMS BRYDOGG76 Nitro On-Road 7 05-19-2009 02:34 PM
Big, mysterious engine problems. Need HELP! stefan Onroad Nitro Engine Zone 42 06-21-2007 10:39 PM
Engine Problems NitroNut Rookie Zone 8 05-06-2003 02:03 PM
HELP! Break-in/Engine Problems with HPI MT 4x4 Kit! paze Electric Off-Road 8 03-10-2003 01:37 PM
