Old 09-10-2009, 06:31 AM   #1
Default "Bibles"
Much like the in depth technical writeups with the Engine Tuning and Engine Breakins, it would be great to see a detailed writeup on dialing in your chassis.
For instance, detailed information on the effects of toe-in and camber, shock mounting position, ackerman, wheelbase, different types of tires and its grip, wing, shocks, shock oil, and all other aspects of the chassis that can be tuned, what its function is, purpose of...
The other bibles are in depth, so for that type of writeup to be applied to the chassis itself would definately be beneifical. Most of us (I assume) are not as pro as the pro's, so coming from one of the self proclaimed or established pro's would be good. Yeah, we got the basics, but would be great if all aspects could be covered anyways.
... everything from the basics, down to the detail...
saki2fifty is offline   Reply With Quote
Old 09-10-2009, 06:36 AM   #2
beta bob's Avatar
Trader Rating: 2 (75%+)
get a hudy set up book they are awesome and very helpful
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 09-10-2009, 08:08 AM   #3
jamiekerr14's Avatar
+1! I just picked up my 808 today which comes with the Hudy Manual aswell... And I should be building it, but I ended Up spending 2hrs reading the book
Yea, You can download the PDF file on the net somewhere not 100% sure where though. Im sure someone on here can link you.
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 09-10-2009, 08:33 AM   #4
madweazl's Avatar
Should be here but I cant confirm it since I'm at work.
madweazl is offline   Reply With Quote
Old 09-10-2009, 09:05 AM   #5
Default Set-Up Theory
Up at work also, but yes... that is a good link.
SET-UP Theory... exactly the point of this post.
Thanks,
Old 09-10-2009, 09:15 AM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
I find this web site to also be greatly beneficial..It tells you why things do what, not just how http://users.telenet.be/elvo/
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-10-2009, 09:46 AM   #7
Brandon_oma#692's Avatar
A long read but so worth it. also has a shorter version you can copy/paste in to word and print
Brandon_oma#692 is offline   Reply With Quote
Old 09-10-2009, 10:56 AM   #8
SET UP all depends on preference. Having a bilble will just be an opinion of one person. There are hundreds of different setup for different chassis whereas tuning and breakin is pretty much the same for every engine
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-10-2009, 11:10 AM   #9
I think the point was more of if i add more -camber in the rear what will it do type explanations for everthing you can adjust. Not a run xx setup for xx car. I use the sheets to get ideas of what to change to make my car do what I want it to do.
This is from the first post
Old 09-10-2009, 11:21 AM   #10
madweazl's Avatar
The effects never change; ackerman will always do x, toe will always do y, and camber will always do z etc.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
Old 09-10-2009, 11:24 AM   #11
But the effects of what they do will differ between manufactors and drivers.
Old 09-10-2009, 11:40 AM   #12
madweazl's Avatar
No, they wont. What you perceive might and the amount of difference they make might.
RadioPost
Old 09-10-2009, 11:48 AM   #13
Sorry bro but they will, I own many 1/8 buggies and truggies and the set ups are different to get them to feel the same way for me.
So your saying that using Drakes standard setup on a Mugen or AE will make them all the same?
Old 09-10-2009, 12:02 PM   #14
megasaxon's Avatar
Trader Rating: 25 (88%+)
Send a message via AIM to megasaxon Send a message via Yahoo to megasaxon
no, he's saying that if you change camber on a losi it will have the same effect as changing the camber on a Mugen. If you put lighter shock oil in a jammin truggy it will have the same/similar effect as putting lighter shock oil in a Caster buggy
Team Associated RC10GT
Team Associated RC10GT2
megasaxon is offline   Reply With Quote
Old 09-10-2009, 12:18 PM   #15
got cha sorry jumped the g un
