Old 09-09-2009, 12:49 PM   #1
Default Please help driveshaft pin stuck
Just changing out my driveshaft pins on my Xray 808. Done them all bar one to do was the front one on the pinion gear
went to take out the small grub screw so used my hudy 1.5mm hex driver quite new put it in properly turned it and bang snapped the tip clean off didnt even round it just snapped it clean off.
so i soaked the driveshaft in oil and got another allen key and it rounded the allen key as it was only a rubbish one i really need it out what can i do. i will try and get another hudy one or maybe a eds 1.5mm if the wosrt comes to worst is there any other way to get the pin out
i need to change it asap
Thanks Ben
BenXB8ec is offline   Reply With Quote
Old 09-09-2009, 01:16 PM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
Thanks Ben
heat!!!!!!! thats all i do
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-09-2009, 03:05 PM   #3
Trader Rating: 19 (100%+)
Yeah... HEAT !!! I'm new to this hobby and one things i've learned is heat is always the way to go. Don't be easy on it either... get a mapp gas burner if you've got one... being a small part don't hold the flame directly on it or you may melt it... but just give it a few passes with a good blue flame (even a jet butane lighter will do) and you'll see smoke piss out of it once the loctite has burnt off. Then while it's still hot try undoing it...
LordAnubis is offline   Reply With Quote
Old 09-09-2009, 03:12 PM   #4
RBMike's Avatar
Just put a hot soldering iron on it for a few seconds & then try.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 09-09-2009, 03:52 PM   #5
Integra's Avatar
I use a Mini Butane torch on stubborn set screws.
Old 09-09-2009, 05:41 PM   #6
RacerScott's Avatar
Thanks Ben
Dude, don't feel bad. I been racing 1/8 scale for 9 years and I just did the same exact thing a few day ago except for me it was a 6 month old 1/16 MIP driver I broke clean off. Also, I wouldn't blame the tools. I have really old HUDY tool set and I never broke a tip with those.
Anyway, I tried a mini torch and a huge torch and the setscrew still wouldn't come out. I twisted a L shape wrench about 5 times. I thought the screw was coming out, but the wrench was twisting.
I had to drill out the setscrew and problem solved, I guess I wont tighten those to much next time and just let the locktite to its job.
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
