Old 09-08-2009, 10:44 AM   #1
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Exclamation How to UNGLUE tires and wheels???
if i buy lightly used tires that are already glued, is it hard to unglue tires and put another set of wheels on them? Thanks and please let me know how if possible
Outtacontrol58 is offline   Reply With Quote
Old 09-08-2009, 10:58 AM   #2
fatdaddy's Avatar
if you dont want the foams, then just put them in a can (like a coffee can) and submerge them in acetone.
if you want to keep the foams, then put a block or some kind of spacer in the can to keep the tires above the acetone. seal the can and let the fumes do the work.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 09-08-2009, 11:14 AM   #3
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
preheat oven to 350 degrees, put tires on a cookie sheet and cook em for 10-15 minutes, let cool and the tires should come off no problem. only glue i have found to need more cooking is fusion. if you are buying wheels just for the rims then you might want to compare the price of them plus hassle vs the rims by themselves.
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 09-08-2009, 12:20 PM   #4
revracr909's Avatar
Trader Rating: 21 (92%+)
+1
Idk about cooking them..Acetone works just finee
Team Associated B44_T4
LRP_REEDY_JCONCEPTS_TEAM EPIC
www.jimmybabcock.com_www.wcrcr.com
revracr909 is offline   Reply With Quote
Old 09-08-2009, 12:24 PM   #5
AcadDude's Avatar
Baking works pretty well. Just get the vent fan going right next to the oven or take outside right away. Fumes aren't to bad but significant others might object. I do 400 degrees for 8 minutes. Let cool and should peal right off.
Consistency is Redundancy . Just lots of wheel time.
AcadDude is offline   Reply With Quote
Old 09-08-2009, 12:43 PM   #6
drs92's Avatar
Trader Rating: 36 (100%+)
Send a message via AIM to drs92
I tried the acetone method and it didnt work!! I tried straight acetone and acetone and water!! But nothing worked, boiling is ok but its the only time I've been succesful in trying to take glued tires off the rim. I think Im going to try the baking next time!
drs92 is offline   Reply With Quote
Old 09-08-2009, 12:49 PM   #7
BigRed's Avatar
Trader Rating: 20 (100%+)
+3!!!
I've tried all the below methods, acetone is the best.
Lake Superior R/C Car Club
lsrcc.com
BigRed is offline   Reply With Quote
Old 09-08-2009, 01:15 PM   #8
slaytanic's Avatar
Trader Rating: 20 (95%+)
Heard people have good luck with acetone but baking works fastest and cleanest for me. Just make sure you wear gloves.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 09-08-2009, 01:56 PM   #9
2fst2c's Avatar
Trader Rating: 114 (100%+)
Boil them. Saves the foams, don't stink up the house and works great. Use an old pot and boil them for about 20 minutes. Put on some good gloves and pull them off.
2fst2c is offline   Reply With Quote
Old 09-08-2009, 03:42 PM   #10
Default Want to save tires, dont care about rims
I am wanting to save the tires i really dont care about the wheels, so will the boiling and acetone method allow me to save the tires, sorry i am just a little confused. Thanks for all the help tho!
Old 09-08-2009, 03:45 PM   #11
2fst2c's Avatar
I'm not sure about the acetone method. Never used it. But when you boil them, the tires will come off and you can re-use the rims foams or tires. Nothing's been damaged when I've done it.
Old 09-08-2009, 04:07 PM   #12
Thumbs up !
ok!
Old 09-08-2009, 04:54 PM   #13
Cory Kerber's Avatar
Boiling works great for me. 10 minutes on each side and the tires peel off and everything is reusable.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 09-08-2009, 06:12 PM   #14
Integra's Avatar
Acetone is imo the best way as it actually melts away the glue and basically your left wityh a clean bead after....baking works but leaves a chunky bead of old glue....baking breaks the bond between the rim and tires....the glue notmally sticks to the tire which can be a Pain to deal with when the glue cools and becomes Rock hard......Boiling i found also didnt remove the glue it just broke the bond between one or the other....Acetone with the Tire elevated out of the liquid is IMO the best way and gives you a clean bead to work with when you go to mount it again.
Old 09-08-2009, 07:31 PM   #15
+1 on acetone elevated out of liquid
TLR 22 3.0 SR,Team Orion, SMC Racing, Sanwa, BOCA Bearings, AKA, Kern Body Works Inc., Rainman's Hobby & Raceway
Sidewayz1 is offline   Reply With Quote
UNGLUING TIRES, ANYONE KNOW HOW? rgrg2 Electric Off-Road 39 09-24-2008 02:56 PM
TNT Discussion - MONSTER TRUCKING!!! BloodClod Singapore R/C Racers 4263 04-13-2006 09:48 PM
how to Unglue, sloopy glued tires? tabarism Rookie Zone 12 05-03-2005 05:37 PM
