Old 09-09-2009, 05:59 AM   #16
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Default elevated?
what do yu mean with the tire elevated out of the liquid? how do you get it to break the glue bonds without getting acetone on the tires?
Outtacontrol58 is offline   Reply With Quote
Old 09-09-2009, 06:06 AM   #17
AcadDude's Avatar
Trader Rating: 19 (100%+)
It's the fumes that do the work. So the tire doesn't need to be submerged.
Consistency is Redundancy . Just lots of wheel time.
AcadDude is offline   Reply With Quote
Old 09-09-2009, 07:21 AM   #18
Integra's Avatar
yupper's....and Dont sit over top the container and breath...you WILL feel it.....seal it and walk away for a day or 2....come back...check and flip tire when needed....the Fume's do the rest.....i use an ice cream pail and fill it with 1/4" of liquid and use a Slurpee lid to elevate the tire...works like a charm...and no Scalding howater or Stinky smokey hot tire's to deal with.
Old 09-09-2009, 08:24 AM   #19
Brandon_oma#692's Avatar
So this takes a week or more? I think you are saying 1-2 days per side per tire??? Seems like a long time
Brandon_oma#692 is offline   Reply With Quote
Old 09-09-2009, 08:52 AM   #20
Integra's Avatar
im never in a rush to remove them...so im sure you could peel them sooner....i just leave them for that long and they peel off effortlessly.....the top side of the bead does start to let go...but the fume's being directly under the tire is where most of the action happens.
Old 09-09-2009, 09:21 AM   #21
what works the best to remove and replace in one day?
Old 09-09-2009, 12:22 PM   #22
AcadDude's Avatar
Boiling requires drying. If the foams are to be reused then they will need to be dryed out. Baking takes less than an hour to cool. I then knock any dust/dirt out of the foams. Clean up the rims a bit if needed.
Old 09-09-2009, 12:46 PM   #23
Integra's Avatar
baking would be the fastest to remove....but the prep work after would kill you on time as the hardened bead of glue is still on the tire itself and needs to be removed before remounting...i would use the Acetone method and soak it....pending on the foams they might be destroyed...but if your in a rush i dont for see any other way.
Old 09-09-2009, 02:48 PM   #24
Trader Rating: 18 (100%+)
Smile answer vidio
you can see the vidio at youtube this is the addreas and this guys have somany kind vidio can help you http://www.youtube.com/user/Squirrelod hopely help
santrully21 is offline   Reply With Quote
UNGLUING TIRES, ANYONE KNOW HOW? rgrg2 Electric Off-Road 39 09-24-2008 02:56 PM
TNT Discussion - MONSTER TRUCKING!!! BloodClod Singapore R/C Racers 4263 04-13-2006 09:48 PM
how to Unglue, sloopy glued tires? tabarism Rookie Zone 12 05-03-2005 05:37 PM
