Old 09-06-2009, 05:44 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Cleaning rc buggy.
Would it be ok to take out the electronics and motor then use a water hose to clean it? If not whats the best way.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 09-06-2009, 05:49 PM   #2
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
full teardowns, 1 section at a time. take this time, and u'll know ur car in and out, it'll look new every time, and a clean freshened up car is a solid car that'll serve u better than folks who skimp
so get out some old towels/rags. unbolt the front end or the rear end and tear it all down and lay it out, then off to the utility sink with a toothbrush and dishsoap.
just hosin off will surely leave water nestled in somewhere and thus...rust never sleeps
R
UltegraSTI is offline   Reply With Quote
Old 09-06-2009, 06:06 PM   #3
jhipps835's Avatar
Okay thank you im leaning towards that way anyways. What should i use to clean? Simple green or glass cleaner? Or just soap?
Old 09-06-2009, 06:16 PM   #4
smb17's Avatar
Send a message via AIM to smb17
I use simple green and a brush. In fact that's what I'm about to be doing anyways
smb17 is offline   Reply With Quote
Old 09-06-2009, 06:29 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
simple green works great. i mix it with water so a gallon will last longer, Then i go and spray wd 40 on the whole truck, let it sit then spray it off. The simple green cleans it, then the wd 40 will take the water away thats mixed in an it makes everything really shinny
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-06-2009, 06:29 PM   #6
On The Edge's Avatar
I agree with ultegrasti. Full tear downs are the way to go to keep everything running smoothly. You can also check for worn or broken parts while you clean it. Simple Green is a good cleaner. Motor spray might be helpful for some areas. The only drawback of the full tear down is that it tends to take quite a long time...
On The Edge is offline   Reply With Quote
Old 09-06-2009, 06:38 PM   #7
cluffy1's Avatar
it depends on what the clean is for. for me the the best clean is a full clean were every pieces is cleaned and inspected peice by piece. but i am in a hurry i just take the radio and engine out, spray it with degreaser and then wash it with water. after it drys I then place oil on all the bearings and screws to protect them from rust.
dane
go hard or go home
cluffy1 is offline   Reply With Quote
Old 09-06-2009, 07:19 PM   #8
sugelle's Avatar
Trader Rating: 62 (100%+)
Remove the radio tray and motor and then I use a cleaner I found to work extremely well. Its called S100 and can be found at most motorcycle or dirt bike stores. It sprays on like a foam and easily hoses off, no scrubbing required!!! I love it !!!! Use an air compressor to blow off any excess water and towel dry. Light coat of WD40 and you're good to go!
http://www.s100.com/s100_tcc.htm
Joe E
SMAC Trac/Dirtburners/Paint by:Snocamel Racing/VP Powermaster Fuel
MP9 TKI3:OS Speed/OS2090/KO RSx servos
ST RR Evo: Ninja BO2/OS 2060/KO RSx servos
sugelle is offline   Reply With Quote
Old 09-06-2009, 07:42 PM   #9
ive been doin the ole meangreen/waterhose/airblowoff/wd40/airblowoff,for years with no problems.just be thorough.... taking things completely apart all the time just wears out screw holes and takes soo long,dont get me wrong.... i do teardowns, just not all the time..mainly for maintanence
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 09-07-2009, 09:37 AM   #10
Originally Posted by crawldad91 View Post
ive been doin the ole meangreen/waterhose/airblowoff/wd40/airblowoff,for years with no problems.just be thorough taking things completely apart all the time just wears out screw holes and takes soo long,dont get me wrong.... i do teardowns, just not all the time..mainly for maintanence
+1 Usually every couple of club races I'll strip everything down and change/clean bearings rebuild diffs/shocks. Do this before every big race as well.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 09-07-2009, 09:48 AM   #11
Trader Rating: 42 (98%+)
Send a message via AIM to RockStar_199 Send a message via MSN to RockStar_199 Send a message via Yahoo to RockStar_199
Odonolle's Speed Wash (Pink Stuff).................best there is and leaves a nice coat of lube throughout the car no water just a compressor blow off
RockStar_199 is offline   Reply With Quote
Old 09-07-2009, 09:53 AM   #12
8&stuff's Avatar
Trader Rating: 55 (100%+)
yer car is only as good as you make it and part of that is a clean rebuild
Mark Buecker
8&stuff is offline   Reply With Quote
Old 09-07-2009, 10:12 AM   #13
Integra's Avatar
Im anal and break it all down and clean it piece by piece with a multitude of brush's & cleaner's.....THE only way to ensure your car is prepped for the next outing is to physically inspect each portion of the car....i cant count how many time's ive seen poorly prepared car's NOT finish the day due to lack of maintenance.
Imo using a hose/water is the WORST thing you can do to your vehicle....Granted if your racing in Condition's like this.http://www.youtube.com/watch?v=Ojp6Z...om=PL&index=20
.it would be acceptable.
Old 09-07-2009, 12:02 PM   #14
wallot's Avatar
motor and electronics off
1. - spraygun with water + simple green
2. - blow dry
3. - GT85
4.- blow dry
check bearings - replace if needed.
done and most of the time ready for next race
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 09-07-2009, 12:32 PM   #15
wfo
wfo's Avatar
Default Rollin' smooth...
I take out motor, electronics, shocks, air as much dirt off as possible then i spray bearing area with WD-40 (before) any water or liquid touches the car...then simple green and toothbrush then air it. more WD-40 I do change out the bearings (AVID) about every other month ... clean/rebuild each part then reassemble and the last thing , a good spray of maxxima SC 1 IMO its better the WD -40 it doesn't attract as much dirt. my cars are spotless and well maintained. Not like the guys who pulled his dirty R/C out of the trunk of his car and wonders why he never finishes a race....
wfo is offline   Reply With Quote
Cleaning up sale!!! Parts, Tamiya RTR's and more! SerpentCT4S R/C Items: For Sale/Trade 20 09-21-2009 02:42 PM
Cleaning out Part 2 M11, Tires, MuchMore, & GTB nsr250repsol R/C Items: For Sale/Trade 15 02-04-2009 05:22 AM
Noob with old Team Associated buggy Mr. Pickles Electric Off-Road 14 04-25-2008 11:17 PM
FS: Basement cleaning - Integy, Yokomo, Ofna, Novak, Bodies! TurboFC3S R/C Items: For Sale/Trade 33 11-09-2006 04:05 PM
cleaning rc cars? MDL Australian Racing 34 02-05-2006 02:13 AM
