OS speed loose front engine bearing
Wondering how loose the front engine bearing is suppose to be.
Mine seems TOO loose. tip the engine and it just falls out of the case with out the crankshaft in there. |
yep, thats loose. How many times has it been changed or taken in our out>? Do you see any cracks?
Originally Posted by ABURTON
(Post 6308402)
I have new TKO bearing as well and it's the same just falls right out |
man...
I have seen it a few times. I put a tiny amount of blue lock tight on it but only if you are sure it is not cracked. If cracked you should be able to look in and see a crack.
Case is done. Typical OS case. All i can say is Good luck, i had 3 go bad, all within a gallon. Was no happy losing 2 vspecs, and a speed.
I have a JX that is the exact same way........... if there isnt a flywheel on it you better keep it in a baggy and keep a close eye on the bearing or its a goner........... Mine runs fine in fact its the best running motor I have with over 9 gallons on it, original rod/p/s........ 3rd set of bearings though.......... if it doesnt cause any tuning issues run it...........
