Old 09-06-2009, 06:34 AM   #1
Trader Rating: 41 (98%+)
Default Hudy set-up
Does the Hudy set-up work real good? Are they worth the money?
longdong1218 is offline   Reply With Quote
Old 09-06-2009, 06:41 AM   #2
yes they work, and to me im happy with the product
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 09-06-2009, 06:45 AM   #3
yes it's good.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 09-06-2009, 07:01 AM   #4
I have a rc8 buggy and truggy. So they are worth 160$
Old 09-06-2009, 07:08 AM   #5
Zerodefect's Avatar
Yes its far more convenient. Alighnment is one of my least favorite part of building/tuneing a car. With the setup station I can get everything dead on and also make allowances for play in the suspension. Much more accurate than useing a camber gauge up against a warped wheel.
Steering symetry is something I've allways had wrong until I got this system. even though there is alot of play in most cars steering they tend to settle in the same place each time you bounce the suspension.
You have to get the droop blocks and droop gauges as well. If your going to to go the lenght of this system you minus well get your droop set perfect as it is more key than camber and toe.
don't get the Hudy board, its expensive and lame. Just get a glass cutting board from walmart for a flat surface.
Zerodefect is offline   Reply With Quote
Old 09-06-2009, 08:47 AM   #6
Thank you sir. That answers my question
Old 09-06-2009, 09:55 AM   #7
totally worth the money for me. makes everything the same every time in a very short time. as long as you dont use it with a losi,they pretty much negate what a station can do for you.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 09-06-2009, 11:17 AM   #8
I would like to add to the info on this thread and ask how often do you put the vehicle in the rack and check or reset? Every heat, before a main, every race day, only if there is a problem? I think I need one of these or I need to find a local guy that can check and readjust it from time to time.
Mr Good Cat
I like to race as much as possible
RC8 E Castle Creations M M !!
Slash Novak Havok !!
Mr GoodCat is offline   Reply With Quote
Old 09-06-2009, 11:29 AM   #9
tallyram's Avatar
i use mine before every practice and race day. if i had more time i would use it between heats and mains also! makes adjustments very simple and accurate!
tallyram is offline   Reply With Quote
Old 09-06-2009, 02:14 PM   #10
Why cant you use it with a losi
Old 09-06-2009, 02:48 PM   #11
Zerodefect's Avatar
Because after a gallon or two of racing there is so much play in some cars that trying to alighn them is a lost cause. Losi and Ae are known for cheap plastic. My old Rc8 needed its arms,uprights,rod ends, shim spacers, shock bushings replaced at least every gallon. It was hard not to laugh at my garbage can being allways filled with Rc8 parts, in the long run it became cheaper to buy an Xray 808. (or 2!)
Its one of the many reasons I only recommend Xray and Mugen kits now. I like a car that lasts more than 1 race.
Same as taking a real car to a tire shop for an alighnment and..."sorry sir we can't alighn your Chevy Pelosi Hybrid because all your ball joints have fallen off."
Old 09-06-2009, 03:26 PM   #12
tallyram's Avatar
you crack me up! my xt8 had just as much slop as my rc8. does it make much difference, nope! who's the fanboy? lol.....
Old 09-06-2009, 03:49 PM   #13
Purdue Engineer's Avatar
I have the complete system with height gauge and droop block for sale. I used them twice. I'm also throwing in the hudy wheel balancer and adaptor in for a package. If anyones interested PM me.
Purdue Engineer is offline   Reply With Quote
Old 09-06-2009, 03:53 PM   #14
Zerodefect's Avatar
Oh come on! Your Xt8 deosn't need the amount of plastic your Rc8 deos to keep going and you know it. I replaced every plastic part on that car at least once and alot of parts 3 times before I got rid of it.
AE and especially Losi need to get with it on plastic issues. Lesson learned, never again.
There is still people out there running old, oooooold Mbx5's.
Old 09-06-2009, 04:00 PM   #15
It was awesome on my 808, but it's useless on the 8ight 2.0. Just get a $10 camber gauge and be done with it.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
EDS vs Hudy tools....or is there something better??? blueryu Nitro Off-Road 51 05-02-2009 09:38 AM
all in one hudy setup station 1/10,rp30 tires and new orion 3600 lipo ehlert R/C Items: For Sale/Trade 13 05-03-2008 07:26 AM
Hudy Set Station supralative R/C Items: For Sale/Trade 14 07-25-2005 09:35 AM
Hudy professional tools vs. ProfiTools? New_Toasted Nitro On-Road 22 10-11-2004 01:44 PM
