Old 09-05-2009, 09:22 PM   #1
jk1152's Avatar
Default Smooth track for qualifiers, Blown out track for the mains? Setup changes?
At some of the larger 2 day events the day of the mains the track can be very blown out. Besides picking a different line, do most of you change your setup before the mains for a track that has become blown out (knowing you will not have any more track time)? I would think maybe raising the ride height? Maybe changing shock oils? I find that after a track is blown out that on certain jumps my rear end will hit the top of the jump and causing the rear to try to flip over the front of the buggy.
jk1152 is offline   Reply With Quote
Old 09-06-2009, 12:53 AM   #2
Zerodefect's Avatar
I add 1/8 turn droop to the front of my car. (about 1mm)
I usually just ride it out with the setup I have. I don't usually see huge track changes unless the race goes on after sunset, but that makes the track better, usually.
Zerodefect is offline   Reply With Quote
Old 09-06-2009, 01:08 AM   #3
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
Depending on how much time i have i will change to harder oils and take out droop so it skims accross the top
if i dont have much time i just change the droop
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is online now   Reply With Quote
Old 09-06-2009, 03:35 AM   #4
juzza99's Avatar
Try adding more kick up on the front end.. I find that helps when the track blows out.
juzza99 is offline   Reply With Quote
Old 09-06-2009, 06:19 AM   #5
wfo
wfo's Avatar
The only set up i really change is that little throttle finger....
wfo is offline   Reply With Quote
Old 09-06-2009, 01:25 PM   #6
If anything, I add a little droop.I tried raising the ride height once, but it just makes it easier to traction roll, especially if you catch a rut.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 09-09-2009, 06:51 PM   #7
counterman's Avatar
Well we run on some tracks here in Minnesota that do this and what I have changed really depends on what type of ruts/holes your experiencing.
Sharp small ruts - normally found on a track that hasn't been watered enough when repairing the hole left from last race! Usually in a clay based track.
Change to a tire that has less side bite. example Change from crossbrace to I-beams. If you can't change or don't want to change, take and cut the side lugs at a 45 degree angle to slide rather than catch the ruts. Take 1 -2 mm of droop away and or lower ride hieght 1-2 mm. You may want to go down in rear anti-squat if running 2 degrees go to 1 degree. If ruts are in high speed area then go up 5 wt in shock oils. You can try combo's of this to get what you want.
Huge holes that you lose you car in!!
If the track is more sand like or true loam then I would do the same with tires but increase droop to max and lighten the shock oils by 5 wt. Leave ride hieght same so drop setting helps. Most of all slow down in the corners and pick your line carefully. All anti-squat setting same as above. Hope this helps.
counterman is offline   Reply With Quote
