Old 09-05-2009, 08:00 PM   #1
ReDnEcK25's Avatar
Default Brake problem
I have a 8ight 2.0 and every since I switch from my dx3s to my Futaba 3pk everytime I hit the throttle my brakes lock up then when I hit the brake it unlockes. I have tryed evrything. what do yall think it could be.
ReDnEcK25 is offline   Reply With Quote
Old 09-05-2009, 08:19 PM   #2
revo61's Avatar
Trader Rating: 18 (95%+)
What about servo reverse?
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 09-05-2009, 08:21 PM   #3
tallyram's Avatar
there should be a menu option like theo suggested, think its just "rev" on the 3pk.
tallyram is offline   Reply With Quote
Old 09-05-2009, 08:29 PM   #4
Brad.R's Avatar
Trader Rating: 25 (100%+)
servo deffinitly reversed, once you get it right, be sure to re ajust trim and endpoints
and just to be clear, when i say reversed, i mean reversed in the radio, not the wires going to the rx
Bad Brad Rutland
Memphis Missle
Ricky Retardo, (Don't lose that number)
Oops my bad, you were in my line..
You just got passed.. IN THE AIR!!
Brad.R is offline   Reply With Quote
Old 09-05-2009, 08:42 PM   #5
ReDnEcK25's Avatar
alright Ill go look and see.
thanks
Old 09-05-2009, 08:45 PM   #6
ReDnEcK25's Avatar
I went and tryed that but no luck it still does the same thing.
Old 09-05-2009, 08:48 PM   #7
jhipps835's Avatar
Trader Rating: 13 (88%+)
That has to be the only explanation. Look in your manual. If you dont have one you should be able to find it online.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 09-05-2009, 08:51 PM   #8
ReDnEcK25's Avatar
I have read that thing front to back and no help so far. The brakes are always on even if I dont hit the throttle.
Old 09-05-2009, 08:59 PM   #9
What exactly are you saying? does the carb open when you pull on throttle & brakes clamp when you push trigger forward? Are your brake rods rubbing on the eyelets they go through when you pull trigger so as the carb opens the brake cams are rotating also. If your servo is moving opposite what your trigger is the only thing it can be is how you have the controler set in the menu. If it was the servo plugged in backwards it would have severe problems or not work at all,sending a signal down the ground wire is not a good thing. So if its not a mechanical problem & its not an obvious problem in the menu the go into the menu on the controler & reset that model back to factory spec(it will have that option) & if that dont fix it check in the menu again & see what mode that model is set to,transmit mode that is.
Just saw your most recent post after mine went up.Its not in fail safe mode is it?your steering works right?
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
How to fix my drag brake problem in my MBX6T? CaptainHowdyt13 Nitro Off-Road 6 08-09-2009 12:53 PM
