Old 09-21-2009, 06:50 PM   #16
sickboy's Avatar
Trader Rating: 72 (100%+)
Its thinned chemically, not watered. I am just curious as to why you would think medium would have more holding power. Thinner glue is going to cover better than medium, creating more holding power do to a larger contact area. Medium is easier to use, but there are alot more benifits of using thin. Like way faster curing and a cleaner glue job.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 09-21-2009, 07:19 PM   #17
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Oh yes of course... "water" would be bad.
Lets see.... I think..... That thin CA, because it is thin, and wicks very well would fill the tiny pours of the rubber and plastic it is trying to bond and create little voids where the contact between the two surfaces would be non exsistant or very thin and weak.
I also think... CA is "chemically thinned" therefor not having the bonding properties that of non-thinned medium or thick Cyanoacrylates do. Also that because medium or thick CA has the ability to bridge gaps further enhancing the strength by not only filling the pours but filling the gaps between the two materials.
I'm not a chemical engineer, but I did stay at a Holiday Inn Express.......
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 09-21-2009, 07:24 PM   #18
losi_racer's Avatar
Trader Rating: 25 (100%+)
LMFAO hahaha
when u glue tires all i do is wipe the tire and rim with motor spray and wrap the edge of the tire with elec. tape and glue with losi standard glue.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-21-2009, 09:29 PM   #19
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Thumbs up
I like losi medium and especially AKA glue. I also like to coat the bead of the tire. I do a clean job as well. I let my buddy glue a pair for me at a away race and he does that spot stuff and the tire were pulling of the bead on the outside wheel in the high speed sweeper.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 09-21-2009, 09:53 PM   #20
houston's Avatar
Trader Rating: 91 (100%+)
sillyboy
losi red
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 09-22-2009, 12:03 AM   #21
losi_racer's Avatar
Originally Posted by houston View Post
sillyboy
losi red
You know, i tried losi thin(red) and its kinda a hit or miss. ive been using the losi standard(blue) and it seems way more consistent. I do the same thing every time and the red sometimes gives and other times it doesnt. The standard stuff seems to hold tight all the time
Old 09-22-2009, 12:39 AM   #22
mblgjr's Avatar
Trader Rating: 86 (100%+)
I've tried a lot of different glues over the past 15 years or so.
Losi Blue is still my "favorite standby".
AKA now has it beat. The AKA bonds and really is better in terms of melting the tire to the wheel better, it's also a touch faster. It makes a stronger bond, faster, without being brittle.
The Ofna "thin" is great when you're in a real big hurry. It's hot stuff for sure. Only did a couple of sets with it, but they've held up fine. It actually takes a little more patience to work with the thin because it does 'wick' so quickly...you have to work a little quicker. And I'm not quick
Proline glues were a real disappointment for me. I think one bottle was doa and was just old; the second; well it ranked strictly mediocre and took forever for the tires to 'set'; probably half again longer than the Losi Med.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 09-23-2009, 05:23 AM   #23
offroad racer's Avatar
losi offroad tire glueing kit
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 09-23-2009, 12:51 PM   #24
houston's Avatar
AKA has some very high quality products
good thing Gil jr. knows what he is doing
his last name is losi ya know
Old 10-25-2009, 05:56 AM   #25
Originally Posted by PTP Racing View Post
Buy premounts
I hate gluing tires.
But alot of the tires from different companies don't have a premount option
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
Old 10-26-2009, 09:41 AM   #26
You only need AKA's.
They have a tread and compound for all race conditions and their whole line up is available premounted.
Jimmy Wright
Old 10-26-2009, 11:49 AM   #27
houston's Avatar
tru dat
AKA tires are great
Old 10-26-2009, 11:57 AM   #28
fatdaddy's Avatar
and he runs a Kyosho! what does that tell you
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 10-27-2009, 05:16 AM   #29
I like to use AKA premount, I take them off the rim and glue them back on with Elmers school glue, it dries clear and I can get it out of my hair and clothes.Seriously I am gonna try Gorilla glue just to see. That stuff is insane one other projects. Did you know it tells you to make sure both surfaces are wet?????
Joey Platinum is offline   Reply With Quote
Old 10-27-2009, 07:50 AM   #30
Gorilla glue works very well on porous materials like wood and not so well on plastic though it will bond somewhat to rubber.
Also with the use of water; Polyurethane reacts or sets off with water. One of the reasons it's used is to help cure as well as in wood working to open the pores of wood to help the glue seek better adhesion.
Also remember to clamp the daylights out of the tires to hold them to the wheels. When the Gorilla glue starts to cure it foams and that foam is strong enough to separate heavy objects.
Try it and share your results here.
Jimmy Wright
How to make custom tires????? Truck_Buster Electric Off-Road 12 10-27-2008 07:10 PM
How to make drift tires? rcjunky1 Electric On-Road 9 09-15-2008 04:42 AM
Can I use ELMERS glue to glue my tires to the rims? Jhyten Electric Off-Road 20 02-25-2006 10:49 AM
how to Unglue, sloopy glued tires? tabarism Rookie Zone 12 05-03-2005 05:37 PM
how to glue rubber tyres? Stevie Rookie Zone 6 05-04-2003 05:24 PM
