Old 09-04-2009, 12:49 PM   #1
Exclamation nitro rc carb is sticking
when i throttle my truck the part on the carb were the low speed needle is at it goes out fine but doesn't go back the whole way. is this an a adjustment problem or is it a carb problem. oh also i just replace the carb body before this started happening.
traxxasman104 is offline   Reply With Quote
Old 09-04-2009, 12:50 PM   #2
and the wether changed a good bit after i put my new carb in
Old 09-04-2009, 01:03 PM   #3
smokinu's Avatar
Trader Rating: 60 (98%+)
as with any sliding part it needs lube so get some after run oil on it and make sure your linkage is not binding.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 09-06-2009, 10:16 PM   #4
sounds like a bur some where.
bigde2001 is offline   Reply With Quote
Old 09-07-2009, 07:08 AM   #5
Sometimes the idle adjust screw is out so far that the slide will close past the point that it should, then unless the slide moves open the idle adjust screw will put a bur in the slide and this will cause it to bind a little.
Joey Platinum is offline   Reply With Quote
Old 09-07-2009, 08:39 AM   #6
dirtyboysanchez's Avatar
Did you seal the carb body to the case? Did you clean the replacement carb before installing it? Also, if you have not checked or changed your air filter regularly some dust may have caused the resistance.... or you may have a hole in the carb boot which will also allow dust to enter the carb body... the dust mixes with the fuel and creates a gummy surface and will cause the carb slider to stick... its very easy to check and clean out...
*Back out the idle screw so you can remove the slider...
*Spray some methanol hydrate into the carb body and slider... wipe off residue...
*Use 2 to 3 drops of after run oil on both the slider and carb...
*Re-install the slider and set the idle screw approx 2mm open...
*ALWAYS use a throttle return spring, for safety from a run away and to help close the carb to maintain idle settings...
*Double check linkage adjustments...
*Re-adjust idle setting/tunning during operation...
This will clean any dust or gummy fuel off the moving parts and should fix the sticking problem, if not, your carb has been damaged and will need to be replaced...
dirtyboysanchez is offline   Reply With Quote
O.S. .12 TZ(P)-T3 Speed Tuned madnitro Onroad Nitro Engine Zone 368 04-07-2013 11:17 PM
TUNING ,3 days in, ENOUGH ALREADY Not_A_Clue Rookie Zone 23 01-12-2008 06:11 PM
Newbie Alert! Can't get my car started! Jastang Nitro On-Road 14 04-09-2006 04:09 AM
Frustrated with my first nitro, help! bcmorrison Rookie Zone 6 02-21-2005 10:49 PM
