Old 09-03-2009, 06:57 PM   #1
Default Possible air leak?
My rc truck (Savage X SS) has been giving me hell with tuning. I suspected an air leak, but hadn't got around to checking.
Well today as I was trying to start the motor, I could hear air coming from the back of the engine. I take the engine off the chassis and using the method by Squirrelod, I check the backplate and exhaust manifold for leaks. No air coming out.
My next thought was an issue with the sleeve/piston. Maybe when it's warmed up there's a small air leak somewhere but not while it's cold.
Do I need to buy any new gaskets for anything before I take this apart or can I just put it right back together if there's no issue ?
Would I be able to tell if there was an issue with the sleeve while it's cold, seeing as how the problem comes up while it's hot ?
Jeimuzu is offline   Reply With Quote
Old 09-03-2009, 07:13 PM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
it's probably the carb,,, they are known to leak and have problems.. look to see if it's wet around the carb..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 09-03-2009, 09:38 PM   #3
And if it's not ? What are some other things it could be ? I'd rather not have to keep coming back after each little thing I check :/
Old 09-05-2009, 02:07 PM   #4
bump
Old 09-05-2009, 05:54 PM   #5
jmackani's Avatar
Trader Rating: 14 (100%+)
Double check the exhaust manifold rubber gasket and make sure the glow plug is tight. You will see fuel bubbles around the glow plug if it is not tight.
jmackani is offline   Reply With Quote
Old 09-05-2009, 09:36 PM   #6
offr0aden's Avatar
First .. is the engine sealed?
Second .. was the engine running fine and then all of a sudden it started to go away?
Third ... If its a fairly new engine... have you had it apart and sealed it before break in? And if its new how much run time / amount of fuel have you run through it.
Forth ... if the above all check out fine or you reseal the engine while you have it out. check the carb low side boot. Its the boot your throttle linkage connects to. This is a common place for air leaks. If there is a crack or the boot is loose, it will suck air. If it loose at all cold it will be worse when its hot. Some use a zit tie and tie the boot where it mounts to the carb. That works in most cases, and will get you bye while you order a new one and then replace it. Some carb have loose boots by design, and in that case get another boot that fits tighter, or use the zip tie method on the new boot.
There are no gaskets that come with the engine, only shims on the head. And unless you have a lot of moisture under the cooling head, and or you head screws are loose, you shouldn't have to reseal it or replace the shims.
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Old 09-06-2009, 05:00 PM   #7
First: No it's not sealed. I plan on doing it tonight or tomorrow.
Second: Not really. I've been having trouble getting it tuned since I started driving it.
Third: First nitro engine ever, and it's not been sealed. I've got about 2 tanks past break-in, all trying to tune it.
I'll seal some stuff up and post the results.
Old 09-10-2009, 10:35 AM   #8
I sealed up the backplate and checked the sleeve for possible damage. The piston and sleeve were fine, and after letting the sealer cure all is well. It idles fine, and I can finally move on to tuning this beast.
Air leak beneath Heat Sink? duratraxrc Nitro Off-Road 7 08-28-2008 12:04 PM
Revo 3.3 air leak? Please help!! matts6887 Monster Trucks 7 07-25-2007 06:15 PM
