Old 09-03-2009, 02:18 PM   #16
Integra's Avatar
Originally Posted by slayyer View Post
no, dont put all 4 aluminum, thats more for a truggy but use 2 carbon and 2 aluminum with gold spring in carbon and silver in the alums. that should work out. you want a harder spring also not softer. and gold is hard
If he is having heat/wear issues.....a stiffer spring will only wear/heat the clutch even more.
Old 09-03-2009, 02:29 PM   #17
deweyharding's Avatar
Trader Rating: 39 (100%+)
Default losi clutch springs
Since I switched to silver on aluminum and gold on carbon my clutches last twice as long as as they did with gold and green springs also engine temps went down.Because clutch wasn't slipping as much?
deweyharding is offline   Reply With Quote
Old 09-03-2009, 02:50 PM   #18
Integra's Avatar
you have a somewhat weak bottom ended motor...and you require that extra stall to get the motor up on pipe and no clutch slipping....you have the perfect set-up if you have long wear low temps and the proper feel you are after....stiffer springs will Normally burn down a clutch as most guys think they need stiffer spring's for the more Hp they have when in reality its the opposite.
what motor are you running ?
Old 09-03-2009, 07:19 PM   #19
Default nova plus 4
I'm running the plus 4 with a standard head and 30%.The bottom is just right if you ask me for what its worth!!! The clutches last gallon and perform perfect for that gallon.
Old 09-03-2009, 08:22 PM   #20
Integra's Avatar
somewhat makes sense....most nova's are linear and aren't overpowering on the bottom end....but generally speaking the higher the stall on a clutch shoe the sooner it will fail due to that much more heat/slip.
Old 09-03-2009, 10:14 PM   #21
tc5 man's Avatar
hows the alum/carbons work on the eight truggy do the carbons ware to fast on them or not enough punch
Old 09-04-2009, 05:06 AM   #22
I am running a WS7iii with a 2045 pipe and long header...
piranha21 is offline   Reply With Quote
Old 09-04-2009, 05:22 AM   #23
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
LOL not a "weak" engine, but maybe a touch soft on bottom.
When I had a Losi I ran the King Headz mount and still had problems with the Losi clutchbells...
If you "flip" the rails it moves the engine forward, allowing you to use "standard" clutchbells... you'll have to rotate your carb slightly to clear the center diff top plate. I personally really like the Racers Edge vented clutchbells- but Mugen, Xray, etc work ok too. (Vented bells can be a problem if you have a sloppy pit man... fuel on the clutch will make it slip...)
You also need to watch the clearance to the tank- if you run one of those pretty endcaps on the crank bolt, things get pretty tight.
Note that the problem I had with the Losi clutch was breaking clutchbells- not the bearings. Evidently there was a weak batch a while back or something. The teeth would break away and you could see the side of the bearings. That problem went away when I went to regular clutchbells that didn't use the larger inner bearing like the Losi does.
As for bearings- we don't remove the shields, but we DO blow them out with compressed air prior to installing them.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 09-04-2009, 07:08 AM   #24
Trader Rating: 24 (100%+)
I never thought to ask if this is in a truggy or buggy?
A truggy needs all aluminum shoes.
A buggy(losi) run two alum and two carbon.
Also, check out this link...
http://forum.losi.com/
All the team guys are on this forum and you can ask guys all the way up to Adam Drake.
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 09-04-2009, 07:18 AM   #25
Trader Rating: 17 (100%+)
has anybody ran a losi clutch system on a mugen with success?
toofast55 is offline   Reply With Quote
Old 09-04-2009, 07:25 AM   #26
http://forum.losi.com/showthread.php?p=2879#post2879
Old 09-04-2009, 07:46 AM   #27
Integra's Avatar
doubt it can work....the losi clutch needs to be used in conjunction with losi bell's...which are alot taller then a standard bell and would put the screw into the tank if not shimmed Just soo....personally i doubt it would work....but that's not to say you cant Make a way for it to work....Almost Anything's possible.
Old 09-04-2009, 10:28 AM   #28
yeah i put it on my engine and clearance for the tank is okay it is lining up with the gears okay maybe alittle foward but not enough to slip or anything just wondering if somebody has tried it already
Old 09-04-2009, 12:34 PM   #29
Integra's Avatar
Interesting.....ill assume No shims behind the flywheel...and the teeth aren't too far forward.....cool....let us know how it works out.
Richfield Raceway in Central PA Victory Side Mid Atlantic RC Racing 5849 01-21-2017 06:03 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Losi 2.0 truggy roller Trevor Williams R/C Items: For Sale/Trade 22 05-10-2009 02:32 AM
Losi Clutch NIGHTMARE!!! motoclay Nitro Off-Road 14 10-06-2008 05:34 PM
What Clutch Shoe are better ? for .21 engine off road Mike.CL Electric Off-Road 12 05-03-2007 10:16 AM
