Old 09-02-2009, 05:30 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Smoke coming out of engine?
Anybody know why this would happen? I preheated my engine to 215 and smoke started coming out of the glow plug. Especially when i took it out. Let me know
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 09-02-2009, 05:36 PM   #2
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 09-02-2009, 05:43 PM   #3
RCmayor's Avatar
Send a message via Yahoo to RCmayor
If the heat gun was directed right at the glow plug it could have melted the insulator. It also may have cooked some oil, after run maybe, that might have accumulated around the glow plug hole.
RCmayor is offline   Reply With Quote
Old 09-02-2009, 05:48 PM   #4
jhipps835's Avatar
So what should i do?
Old 09-02-2009, 05:50 PM   #5
jhipps835's Avatar
The engine isnt ruined is it?
Old 09-02-2009, 05:50 PM   #6
jhipps835's Avatar
Also there was i could see oil towards the bottom of the cylinder head.
Old 09-02-2009, 05:50 PM   #7
smb17's Avatar
Send a message via AIM to smb17
Do you put after run oil in? After run oil makes a nice plume of smelly smoke.
smb17 is offline   Reply With Quote
Old 09-02-2009, 05:54 PM   #8
fast11970's Avatar
Take the plug out, see if it works, put a drop of oil or a drop of fuel in it and if it looks ok, fire it up...I do not heat them on the head, I heat it up uniformly, on the block, left, right,and rear...heat rises.
MBX6
http://www.racemugen.com
fast11970 is offline   Reply With Quote
Old 09-02-2009, 05:57 PM   #9
jhipps835's Avatar
Ok i took it off but no smoke came out. It must have all came out with it in. But the piston is now stuck at top dead center and the engine was still at 190. Is that cool enough to make it stuck?
Old 09-02-2009, 05:57 PM   #10
jhipps835's Avatar
oh and no i didnt use after run oil
Old 09-02-2009, 06:21 PM   #11
jhipps835's Avatar
Would the insulator being melted affect the way the engine runs? Because when i started it, it wouldnt stay running . So i a am guessing it does but a confirmation would be nice.
Old 09-02-2009, 06:35 PM   #12
xlgraphicspro's Avatar
did you have the glow plug all the way tight? if not exhaust will come out from around the glow plug. that insulator is made to withstand high temps, so I doubt that's what was smoking.
everytime your done running the engine, you have to rotate the flywheel down to where it feels free opposite of Top Dead Center. if it's stuck at top use a flat blade screw driver to rotate the flywheel free, and rotate it down. you have to do that before it cools down if you don't want to cause damage.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 09-02-2009, 06:36 PM   #13
jhipps835's Avatar
Yea for some reason the glow plug came loose. And yea just to be sure i took the entire exhaust off so i could see the piston at bdc and thats where it is at now. Would the smoke cause the engine to act funny? Because when i started it the engine wouldnt stay running but yesterday it would
Old 09-02-2009, 06:50 PM   #14
Stubbs's Avatar
Trader Rating: 57 (100%+)
When you've got your piston at BDC, grab a paint pen or some fingernail polish and put a mark on your flywheel that you can reference again. Put it whatever position you want, 12 o'clock, 6 o'clock, 9, etc... Just make it easy to remember. That way, you can very quickly spin your motor down to BDC.
About the glow plug, the copper washer has a "dish" to it. You should always install it with the dish facing down (picture an upside down bowl). If it's on upside down, the plug may not seal, and you can get leakage...or course, this is assuming that you're not using a Turbo plug. If you are, ignore what I just said...
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 09-02-2009, 10:03 PM   #15
Jaz240's Avatar
Trader Rating: 52 (100%+)
It is very likely that your plug has fouled during the break in process..Put a new plug in it and it should run just fine
nothing to see here................................
Jaz240 is offline   Reply With Quote
Engine Compression. tkhoo Nitro Off-Road 16 08-19-2009 06:07 AM
Engine Tech x_man Malaysian R/C Racers 745 11-27-2007 11:05 PM
smoke coming out of the tank? drumax1016 Rookie Zone 7 03-03-2006 10:15 PM
fuel comming out of exhaust alucard13 Nitro On-Road 30 04-12-2003 07:48 PM
Question concerning my new engine, Please help! Ducati998 Nitro On-Road 13 02-14-2003 09:41 PM
