Old 09-02-2009, 06:36 AM   #1
Default Need help inserting the brass eyelet inside the rubber grommet for my servos
Has anyone else had issues trying to install the brass eyelet inside the rubber grommet on the servos? When trying to install the brass eyelets (from the bottom side going up) they push through, but at the very top they get stuck and don't make it all the way or close to the top of the rubber grommet so that they are showing. Instead the rubber piece gets in the way and is pushed up a bit. Is there a trick to pushing the brass eyelets through? Thanks.
Ryno RC is offline   Reply With Quote
Old 09-02-2009, 07:39 AM   #2
Stanton's Avatar
Put the eyelet on a hex wrench or any type of screwdriver that has small enough shaft for the eyelet to slip over.Just push it in the grommet. It is super easy!
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 09-02-2009, 08:24 AM   #3
Lonestar's Avatar
err... push harder?
(and spray the hole with WD40 or drop a droplet of shock oil in there)
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 09-02-2009, 08:30 AM   #4
They go through midway, and then get stuck before making it to the top. It gets caught on the inner rubber part.
lol...i pushed so hard that my fingers were sore as can be and still feeling the repercussions this morning. ha. I will try the shock oil trick, maybe that will help.
Old 09-02-2009, 08:43 AM   #5
Sam-E's Avatar
I do not use rubber grometts on my servos, ditch em and save your hands.
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 09-02-2009, 10:42 AM   #6
Integra's Avatar
Vibration's from nitro 1/8 off-road are Servo Killer's....the grommet's are included for a reason....USE em....i personally dont use the brass inserts but just the rubber's.
Old 09-02-2009, 12:17 PM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Practice safe racing... user rubbers!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 09-02-2009, 12:18 PM   #8
Integra's Avatar
Old 09-02-2009, 12:45 PM   #9
underway's Avatar
Trader Rating: 48 (100%+)
+2
Put the grommet on the servo first then use a pair of pliers to press the brass piece in place, ... takes a little practice but after a while it becomes easy.
underway is offline   Reply With Quote
Old 09-02-2009, 01:14 PM   #10
Trader Rating: 21 (100%+)
The brass needs to go in from the top (side where you would put the screw)
TopGearRC is offline   Reply With Quote
Old 09-02-2009, 06:12 PM   #11
Sam-E's Avatar
I am hearing you Integra my man but my servo's are 3+yrs old and still going strong, I had them rubber mounted for a few months but then ditched the rubber.
But then again I dont run hitecs!!!
Old 09-02-2009, 08:44 PM   #12
Integra's Avatar
Hitec is the King...there's no 2 ways about it.
