Old 09-02-2009, 03:29 PM   #16
sickpuppy1's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Mike Marshall View Post
Dude you are lazy, and irresponsible!
AND whatever too!
sickpuppy1 is offline   Reply With Quote
Old 09-02-2009, 05:56 PM   #17
HaulinBass's Avatar
FYI almost all cheap "temp" guns are set up to read NiMh batt packs, and must be set up acording to the color of the anodizing and the alloy of aluminum.
If your temp gun was under $100 I wouldnt trust it, but then again I havnt used any temp gun in years.
HaulinBass is offline   Reply With Quote
Old 09-02-2009, 06:16 PM   #18
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
ice water, 32deg F or close obviously. How we test freeze stats on air handling units. have to be close b/c of the FSs are not set right and the coils burst b/c of freezing. then all/part of a buildings heating (heat comes 1st) and/or cooling could be destroyed and in many cases 10s of thousands to fix. so a lil styro cup of ice water time and again has no equal in terms of giving a mechanic a fixed temperature from which to reference.
R
UltegraSTI is offline   Reply With Quote
Old 09-02-2009, 10:43 PM   #19
But thats not the problem with cheap temp guns. They may read 32 degrees fine but high temp I've seen as high temps over 200 be 50 degrees off or more. I've been bit by that before driver said engine fan wasn't coming on temp gun vs ECM was seeing. Changed coolant temp sensor for nothing beside the hot engine. Fan was working driver wasn't uses to the high engine temps.
Cheap temp gun went into the trash bought a good one from Matco tools.
pdmustgt is offline   Reply With Quote
XXX-NT AD2 Thread DemonLosi Nitro Off-Road 2245 06-06-2017 01:16 PM
APS 3-in-1 Dyno Charge Rob Phillips Electric On-Road 268 10-17-2009 10:26 AM
Engine leaking catkchun Malaysian R/C Racers 37 09-23-2007 05:38 PM
Temp guns... again D_o_S Nitro Off-Road 26 07-25-2007 12:15 PM
Swapping fuels, help please... RiceEatin1995GT Nitro On-Road 21 11-30-2005 11:30 AM
Newbie questions WillB Rookie Zone 15 02-08-2005 08:21 AM
