Old 09-01-2009, 05:39 PM   #1
Default starter box problems??
So I bought a used starter box and brought it home it had some charge but it was not dead yet, it had a 12V gel cell so I charged it over night and tried to start my buggy, it died with in a couple minutes so I threw it back on the charger all day got home and at first it seemed like it was fully charged and it also died with in a minute....so I went to the hobby shop and bought 2 stick packs wired them to get 14V and put them on the charger then wired up the starter box and I'll be damned if it does dot go dead within a couple of minutes ...so I charge them again and lone be hold their dead again in a couple of minutes
I know there is not a short
I know the packs are bran new and fully charged
I have looked everything over and over
PLEASE HELP THIS IS BUMING ME OUT
smokescreen1139 is offline   Reply With Quote
Old 09-02-2009, 12:26 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
what kind of box
did you put 14v to a 12v motor?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 09-02-2009, 12:46 AM   #3
Echelon's Avatar
Maybe ur charger is causing the problem
Echelon is offline   Reply With Quote
Old 09-02-2009, 01:16 AM   #4
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
Possibly the actual starter box motor.
Funking-Awesome is offline   Reply With Quote
Old 09-02-2009, 04:09 AM   #5
its an ofna true start I used 2 different types of chargers, I was kinda leaning towards the motor, I was wondering if anyone else ever had any of thease problems
Old 09-02-2009, 04:26 AM   #6
Trader Rating: 47 (100%+)
Does the box have a powerpanel on it?
If so try disconnecting the panel.
rageworks is offline   Reply With Quote
Old 09-02-2009, 06:16 AM   #7
Frank L's Avatar
Trader Rating: 148 (100%+)
Also check inside the box where the contacts are there's a spring and brass washer and 2 contacts that send juice to the engne when the top of the box is depresses and the circut is completed. This is the weak spot on most boxes
Old 09-02-2009, 06:57 AM   #8
scwrod's Avatar
+1 above
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 09-02-2009, 10:48 AM   #9
noR
noR's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to noR Send a message via MSN to noR Send a message via Yahoo to noR
+1 to Frank's statement.
Maybe the batteries are okay, and the physical switch is failing.
Happened on my Ofna. Replaced w/a cheap metal washer; good as new.
Check out my local track --> http://trackseeker.lefora.com/2009/05/01/trackseekers-18-scale-offroad-track-04302009/page1
noR is offline   Reply With Quote
MBX5R with OFNA starter box problems.. pracy Nitro Off-Road 13 05-12-2008 03:55 PM
starter box problems TC3 BUDRACER1 Rookie Zone 7 09-09-2003 01:15 PM
