Old 09-01-2009, 03:59 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Flywheel lock.
Does anybody know why my flywheel would lock after a couple runs. Im just breaking in a engine and i just tried to start it again but the flywheel wont mobe at all. Any help?
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 09-01-2009, 04:03 PM   #2
rcgeezer's Avatar
Your motor most likely still has that "new pinch" feel as it's not yet broken in. Heat the motor to about 200 degrees and it should loosen up enough to turn over and start. It's a good idea to continue heating it all the way through it's break in process...the rod will love you for it!!
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 09-01-2009, 04:07 PM   #3
jhipps835's Avatar
Oh yea ive been heating it. I dont think its because of the pinch. It wont move at all. Like before i could move it then it would stop once it gets to the tight pinch but now it wont move left or right and when i hit the bump box it just seems like the bump box is getting worn down.
Old 09-01-2009, 04:16 PM   #4
jhipps835's Avatar
anyone know why this is happening??
Old 09-01-2009, 04:22 PM   #5
Jaz240's Avatar
Trader Rating: 52 (100%+)
Did u let ur motor cool down with the piston at the top of the sleeve? If so you are going to have to heat it to 225 or more to free it up
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-01-2009, 04:26 PM   #6
jhipps835's Avatar
No i made sure it was at bdc after i shut it down. Ive heard some people talk about hydrolock, not sure what that is though. Anyone know?
Old 09-01-2009, 04:28 PM   #7
fatdaddy's Avatar
pull the glow plug and see if that helps at all.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 09-01-2009, 04:29 PM   #8
Jaz240's Avatar
Just means the engine is flooded..try taking out the glow plug and see if you can turn the flywheel
Old 09-01-2009, 04:46 PM   #9
jhipps835's Avatar
Ok i got it thanks for the help james. I guess it did cool off at the top of the sleeve.
Old 09-01-2009, 04:50 PM   #10
sugelle's Avatar
Trader Rating: 62 (100%+)
becareful or you will do some damage!!! Make sure that you are heating the engine up each time you attempt to start it. Ideally you need to heat up to 200-210 degrees. As soon as you stop the motor, make sure you move the piston to BDC.
Joe E
SMAC Trac/Dirtburners/Paint by:Snocamel Racing/VP Powermaster Fuel
MP9 TKI3:OS Speed/OS2090/KO RSx servos
ST RR Evo: Ninja BO2/OS 2060/KO RSx servos
sugelle is offline   Reply With Quote
Old 09-01-2009, 05:09 PM   #11
jhipps835's Avatar
I do that everytime so nothing to be worried about.
Flywheel Nut jhipps835 Nitro Off-Road 23 08-31-2009 05:40 PM
Hi. I'm looking for the proper flywheel tool helgso Nitro Off-Road 7 08-19-2009 07:19 AM
Flywheel problem. jhipps835 Nitro Off-Road 15 07-15-2009 02:40 PM
Locking the flywheel so I can remove the clutch nut on Losi 2.0 Garet Jax Nitro Off-Road 26 07-07-2009 02:51 PM
flywheel is sticking jedro1 Nitro Off-Road 8 05-01-2009 03:13 PM
My flywheel is coming loose help. Smoke21 Nitro On-Road 10 01-16-2004 05:22 PM
