Old 09-01-2009, 05:22 AM   #1
Default clutch bearing issues
hello and thanks for reding i have a jammin 28 in a jammin x1 and i keep blowing out clutch bearings mostly frnt bearing but has blown rear one . Gear mesh is correct had others look and feel it and end play is fine a little over .5 play a spec i've read in several different tuner books and mags. any other reasons why they would blow out so quickly, running a 5 min qual. and frnt bearing inner race is gone, idd not explode yet but seal is gone and bearing is starting to go. Yes these are new bearings again mesh and end play are correct if not even a little more gap then needed. Im really leaning to 3 things. 1. chassie flex while driving flex pintching out clutch and messing gear mesh. 2. bad set of bearing but all new out of wrapper from protec and reedy bearings black and green seal metal backed 3. tip of crank is slight bent and at idle is hogging out bearing while at idle ...? any suggestions may help have been racing now for 4 or 5 year bashing since "88" but have never run across this issue any help would help thanks
STEVE SACHUK is offline   Reply With Quote
Old 09-01-2009, 05:26 AM   #2
l3asher's Avatar
Have you tried a new bell??
l3asher is offline   Reply With Quote
Old 09-01-2009, 05:30 AM   #3
losiracer78's Avatar
sounds like you answered you own question my friend the tip of the crank shaft being bent cause the front of the shaft to vibrate which is not good for the bearing and the front bearing is going to vibrate alot more because its closer to the bend
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 09-01-2009, 05:34 AM   #4
elkman's Avatar
Default King Headz
King Headz makes an extended engine mount for your truck. It will help take the chassis flex out of the picture and may keep the clutch from getting tweaked and eating your bearings. The extended quick change mounts are only about $45.00 or so. Sounds like you are going through that amount of money in bearings pretty quick. My son has a KHZ extended mount in his 8IGHT-Truggy and it seems to do good. I am going to get one for mine soon.
One thing that may be a factor is how you are installing the bearings. Make sure you are pressing them in place by pushing in on the outer ring not by pushing in the very center. It can stress the bearing quite a bit. If the bearing is a really snug fit I will use a socket that is the exact diameter as the outer ring on the bearing and press it in with that, I don't even push in on the center at all.
Kinda like pressing in crankshaft main bearings on a life-sized car engine.
Good luck.
"He's old enough to know what's right
But young enough not to choose it"
Neal Peart / Geddy Lee
****RUSH****
elkman is offline   Reply With Quote
Old 09-01-2009, 06:57 AM   #5
noR
noR's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to noR Send a message via MSN to noR Send a message via Yahoo to noR
Could it also be a bind in the drive-train? Causing more load on the clutch allowing for more slip, or more heat.
idk, I had alot of bearing problems myself a while back. They seem to have calmed down a bit though.
Check out my local track --> http://trackseeker.lefora.com/2009/05/01/trackseekers-18-scale-offroad-track-04302009/page1
noR is offline   Reply With Quote
Old 09-01-2009, 09:20 AM   #6
Paperman 90's Avatar
hey i had crt 1 that was doing the same thing i to had to put a z brace on mine and that help
Hot bodies D8
MBX 5T Go 7port .21
Paperman 90 is offline   Reply With Quote
Old 09-01-2009, 10:14 AM   #7
PTP Racing's Avatar
I know a guy who had the same problem with those engines. We theorized it had something to do with the crank balancing. If yours is bent at all that is more than likely the cause of your problem.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 09-01-2009, 11:31 AM   #8
Default bearing
thanks for all the tips ill try it i have a different motor going to try that vspec again
Old 09-01-2009, 01:38 PM   #9
j_blaze14's Avatar
Trader Rating: 34 (100%+)
chassis flex
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 09-01-2009, 01:57 PM   #10
losi_racer's Avatar
Trader Rating: 25 (100%+)
its not chassis flex. in my 8t and now 8t 2.0 and also in both my dads truggys, We never ran the extended motor mount and never blew bearings like that. If i wanted to(he does) i could just replace bearings when i replace the clutch, we use avid bearings.
i did have an problem like you are in my buggy tho, every race was a chance to blow my pads from bearing failure. Ended up being my front bearing of my engine leaking a slight which was causing my bearings to go.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Losi Clutch Bell Bearing problems. l3asher Nitro Off-Road 36 05-16-2010 09:31 AM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
Clutch Bell Bearing Issue 843rcguy Nitro Off-Road 18 08-22-2008 10:09 AM
clutch bearing problems cwalters Electric Off-Road 39 09-11-2006 06:59 AM
Thrust Bearing Question Please TRFTIM Nitro On-Road 26 05-25-2006 06:56 PM
