Old 08-31-2009, 03:32 PM   #16
jhipps835's Avatar
Trader Rating: 13 (88%+)
Well no matter how much i tighten it the flywheel still spins freely. I can tighten it anymore either and now i cant even take it off.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-31-2009, 03:34 PM   #17
fatdaddy's Avatar
sounds like you have the wrong size collet for that motor.
you should be able to use whatever procedure to take it off as you got it on
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 08-31-2009, 03:48 PM   #18
jhipps835's Avatar
I know for a fact i have the right collet. And its based of the car not the motor isnt it?
Old 08-31-2009, 04:17 PM   #19
omarwashington's Avatar
here is an alternative to zip ties
Dynamite Crankshaft Locking Tool
http://www.amainhobbies.com/product_...ing-Tool-12-21
RCCARS!
omarwashington is offline   Reply With Quote
Old 08-31-2009, 04:26 PM   #20
fatdaddy's Avatar
i think some of them are different. when you put the collet on the crankshaft did it have alot of slop?
Old 08-31-2009, 04:39 PM   #21
RBMike's Avatar
Get a new collet. For Losi it's the same one that goes on the gas truck. Or the inside of your fly wheel may be worn.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 08-31-2009, 04:48 PM   #22
jhipps835's Avatar
I dont have the time to guy buy new tools right now nor the money. I guess i have to buy a new collet even though they are all the same.
Old 08-31-2009, 04:49 PM   #23
jhipps835's Avatar
Is there anything i can put on the inside of the collet to make it grab the crankshaft better?
Old 08-31-2009, 05:40 PM   #24
fatdaddy's Avatar
take your motor, collet, and flywheel down to your LHS and go through what they have there.
there are different collet sizes depending on the crack diameter. not all of them are the same.
for example: http://www.amainhobbies.com/advanced...40&filter_cat=
notice one is for 6mm picco, and the other 7mm novarossi
Flywheel nut help! jhipps835 Nitro Off-Road 19 08-04-2009 02:46 PM
Flywheel problem. jhipps835 Nitro Off-Road 15 07-15-2009 02:40 PM
flywheel is sticking jedro1 Nitro Off-Road 8 05-01-2009 03:13 PM
Clutch Nut is, well...stuck paco62 Nitro Off-Road 25 03-10-2008 11:54 AM
