Old 08-31-2009, 09:51 AM   #1
Bobby56's Avatar
Default Head shim for ninja?
was wondering how many head shims should you be running on a 21 with 30% nitro fuel. my ninja came with 2 on it and an extra one, so i put the 3rd on when i started running 30% after break in
Losi 2.0 Buggy, Ninja, Dalton RC
Bobby56 is offline   Reply With Quote
Old 08-31-2009, 09:58 AM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
run the stock shims with 30%.. if you run 20% you can pull the one brass shim out..
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-31-2009, 10:01 AM   #3
Bobby56's Avatar
so your saying only run 2 with 30% instead of 3 like im running now right
Old 08-31-2009, 10:06 AM   #4
jpalessi's Avatar
stock...1 silver and 1 brass. the extra 1 in the box is just an extra that should stay in the box.
Joe Alessi
www.Lucky7RC.com
Old 08-31-2009, 10:18 AM   #5
Bobby56's Avatar
mine came with all brass im pretty sure but will dbl check when i get home and repost. thanks. but should be .3mm of head shim when u run 30% correct
Old 08-31-2009, 10:28 AM   #6
jpalessi's Avatar
Default JX .21 shimming
the stock engine comes shimmed for 30% with 2 shims.
1 silver shim .008", and 1 brass shim .004
running 20% you could pull out the .004
Joe Alessi
www.Lucky7RC.com
Old 08-31-2009, 03:49 PM   #7
i am running 20% and have the head gasket and one shim. Would i get a performance advantage if i take out the copper shim?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-31-2009, 05:22 PM   #8
Bobby56's Avatar
thanks guys when i got home i did have one two many shims so i took one out and left one silver and one copper, man does it run alot better. thanks again.
Old 08-31-2009, 08:25 PM   #9
Adro's Avatar
what head gasket?? there should only a silver and a copper shim, no gaskets.
if you have anything else in there other than 2 shims take it out, if you are running the 20% take the copper shim out aswell.
Adro is offline   Reply With Quote
Old 08-31-2009, 08:31 PM   #10
Adro. I promise you that silver shim is a head gasket. Gasket's are not just made out of rubber and fiber mesh. THere are aluminum and metal gaskets as well. The compressors out at exxon have gold plated ones. It is to seal the head. they could be called shims too i guess. But if you don't have any in, it will suck/blow air.
Mugen
Old 09-01-2009, 02:24 PM   #11
Adro's Avatar
fair enough, i have never heard them called a gasket before which is why i said it.
Ninja Engine by GRP ogreasurada Offroad Nitro Engine Forum 1526 09-16-2013 07:13 PM
World Championship for GP 1/10 fatboy Malaysian R/C Racers 45 08-19-2008 08:27 PM
jp b5 or ninja b01 slowpokeRRR Electric Off-Road 25 12-10-2006 08:28 AM
Ninja MR21B01 Carb settings? xlgraphicspro Electric Off-Road 13 07-30-2006 06:00 PM
