Old 08-30-2009, 08:58 PM   #16
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Not every motor is the same. Stop listening to the HAS to be over this temp crap. Honestly, if your engine is running at what you think if very good performance and its putting out good smoke, your fine, your engines perfect.
Thats it, you dont need an exact temp. I only use my temp gun to make sure my engine isnt over heated i dont constantly check it. Only after races to make sure its running well. You dont need a temp gun at all really.
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 08-30-2009, 09:02 PM   #17
Pinky knows whats up.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 08-30-2009, 09:34 PM   #18
wingracer's Avatar
Trader Rating: 23 (100%+)
Throw the damn temp gun away. It's a waste of money.
Well ok, I do use one that was given to me for free for break-in but that's it.
Once you get a little experience with these motors you should be able to tell if it's lean without a gun and if it's rich but running 300, richening it more is not going to solve the problem.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-30-2009, 10:28 PM   #19
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
Originally Posted by dreaux View Post
I am about to throw away my temp gun.
Good idea.
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 08-30-2009, 10:39 PM   #20
savage.25's Avatar
Send a message via MSN to savage.25
tune for performance not temp. i rarely use a temp gun on my STS .28 hell even on the stock .25 engine i only used a temp gun on it a few times. like others have said as long as there's blue smoke coming out when you hit the throttle ur fine.
savage.25 is offline   Reply With Quote
Old 08-30-2009, 11:08 PM   #21
Originally Posted by Davidka View Post
Nothing outperforms a properly tuned V-spec by a decent margin.
*caugh *caugh
cheapskate.brok is offline   Reply With Quote
Old 08-30-2009, 11:24 PM   #22
smb17's Avatar
Send a message via AIM to smb17
Someone hasn't been on neo-buggy lately! O.s has some competition!
smb17 is offline   Reply With Quote
Old 08-30-2009, 11:27 PM   #23
Trader Rating: 47 (100%+)
Not too much smoke though. You want to be
able to see those big pick-up trucks parked
in the street.
rageworks is offline   Reply With Quote
Old 08-31-2009, 03:12 PM   #24
madweazl's Avatar
life. I have been beating my head agaist the wall and tunning my poor engine too lean to get the temps everyone says you have to have to get the engine to run at optimum performance. Well i reset my needles for the best power reguardless of temp. And it stays in the 180 maybe 190 range. And my ninja already outperforms my vspec by a decent margin. It has crazy bottom and top. Fastest buggy on the track. and i still can't turn over the flywheel with the glow plug out after a gallon, i can when it's hot though.
i preheat my engine before every run too.
So, no one can ever convince me that a engine has to be over 200. Tunning to temps is ridiculous. I am about to throw away my temp gun. But it is still usefull for preheating and to guard from overheating (if that ever happens)
I am tired of people saying get it over 200, wrap a sock, wristband, foil around it etc etc.
bull crap.
If it's running well in that temp range, dont change anything. Gearing will have an affect on your temps as well. I use to try and keep everything around 200-210 but it was impossible with the gearing I preferred on some tracks. It would run perfect at 225 so I just started leaving it there. I didnt notice the life of the motor degrading at all. I usually run as lean as safely possible because I get great throttle response and good mileage.
madweazl is offline   Reply With Quote
Old 08-31-2009, 03:53 PM   #25
houston's Avatar
Trader Rating: 91 (100%+)
ninja/grp do not usually run hot
they are built very efficient
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-31-2009, 04:47 PM   #26
JayL's Avatar
where are you temping it?
How long after your 7-10+min run are you temping it?
JayL is offline   Reply With Quote
Old 08-31-2009, 05:52 PM   #27
i haven't put my restrictor in yet. I will have to retune correct? and since i have no factory settings on my ninja i will just put the low end flush and the high end 2.5 or 3 turns out. I do have a issue with tunning just the high speed needle first. I do but i have to lean the low in a bit too to get a good read on the high end.
So will the restrictor maybe make it run hotter? I don't know why i have not put it in yet.
When you put the restrictor in, you will need to lean the motor to compensate for less air going into the carb. As a benefit, your fuel mileage will be better with the restrictor in than without. The addition of the restrictor will no doubt have some effect on the tune thus requiring you to retune the motor thus different head temps. There are alot of things that can affect head temps, plugs, fuel, pipe, air filter condition, etc.
Manufacturers all use different operating temps as ideal temps so that when the sleeve expands due to heat, the piston is still able to seal and have compression. Running to cold wont kill a motor, but it will shorten the life of the rod and the crank pin.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 08-31-2009, 06:02 PM   #28
i am running oddonell 20% with a re11 losi pipe. P3 plug. no restrictor, 1 head shim.
I am told that if i am running 20% i can take the copper shim out and just leave the silver head gasket.
I am going to retune with the restrictor and no shim.
and while i am at it, new clutch shoes, bearings, springs.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-31-2009, 07:10 PM   #29
bcr500's Avatar
Trader Rating: 34 (100%+)
My nova p5 runs great at 180 to 190!!!!
MBX6R
XRAY XB808
NOVAROSSI
bcr500 is offline   Reply With Quote
Old 08-31-2009, 08:24 PM   #30
houston's Avatar
keep it
