Old 09-26-2009, 10:35 AM   #61
Maximo's Avatar
Originally Posted by 8&stuff View Post
I normally seal every engine i get and didnt this one. i was running 086 with short header. switched it 2 tanks ago for 053 and long header for the indoor season. Any other pipe youd suggest? il seal the carb base and i have no doubt that this will resolve issue. if not il try different button.
it is not the base that leaks ...it is the seam on the carb body between the composite body and the metal end cap...
Maximo is offline   Reply With Quote
Old 09-26-2009, 10:41 AM   #62
8&stuff's Avatar
Trader Rating: 55 (100%+)
cool. i hadnt sealed it there yet so i will. thanks for your time on this. im not sure how much this engine will be ran between now and spring cause of small indoor racing although il let know how goes.
8&stuff is offline   Reply With Quote
Old 09-27-2009, 01:02 AM   #63
Hay guys ran this moter today at club race.Was going to race at ks. pro series race today but was rained out.Race was postponed to sun. so i get to race two days ! This moter ran great all day but was still breaking in so i was unable to get a full race tune on this mill.This moter is a handfull to drive with my current setup even with very rich seting . This thing is a monster Very snapy and powerful . Moter was very rich in my main but still had plenty of power to clear jumps . Good enough for 2nd place in the a .I think it droped its nuts in the main because it got real rich bout 3 mins. into race came off at 170F. Right now im running this in a heavy D8 carbon shoes 1.1 clutch springs 8mm. res. and a msr1005 pipe on 30% byrons . Going to install 1.0 or 0.9 clutch springs to soften the hit.Very happy right now will see how it goes sun.
BeefHead is offline   Reply With Quote
Old 09-27-2009, 01:33 AM   #64
Guys FYI. the needles on these are more sensitive than other mills. So take your time to adjust your tune and all is well.Seems like 1 hour on this carb is like 2 on others.And make sure you seal the carb real well.Unlike other moters where you are trying to find the power you want this moter has more than enough.You might find your self detuning this mill for some tracks.If you are finding that this moter is to much like on a slick or low bite or is just to much for you to handle in the past i have found the TTR2035 pipe and 0.9clutch springs do tame this beast.And run time with the TTR2035 is very goodThe 2035 will take away some Hp. and top end but will still smoke every mill on the track
Old 09-27-2009, 07:39 AM   #65
Trader Rating: 61 (100%+)
pretty cool homemade rig there max .....i know alot of people are using break in stands you know more inside like in garages with ventilation ...most i see dont use an air filter ..partly due to being inside ...partly due to finding a rig with the right bend in it to stay out of the way of the propeller ...what do you think about not using an air filter in the right controled area such as inside with ventilation? also what did you use there for your airfilter ? i should be getting an rd logics break in bench befoore the start of next season ...i cant wait ...as i have been seeing alot of people using them ...just seems like the way to go for break in ...thanks ...
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 09-27-2009, 09:34 AM   #66
Maximo's Avatar
086 IMO the best matched pipe for this engine.... my second favorite is a JP4.......I have ran a 1005 and felt it was too peaky, also a 2035 but felt it killed the midrange and top end too much....the 086 is perfect !
Old 09-27-2009, 09:45 AM   #67
coviello's Avatar
what would it cost to get one modded? and where is neal located?
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 09-27-2009, 09:50 AM   #68
8&stuff's Avatar
Thank you for your help Neil! very much appreciated.
Old 09-27-2009, 10:34 AM   #69
Maximo's Avatar
The RD bench is good...we use the RD prop and cone setup which allows us to use a small airfilter.....If your careful having no filter should be fine... you could also stretch a small piece of oiled fabric over the neck if you don't have enough room for a filter..To me anything is better then nothing, tho i know many who don't use any filter and have no issues
Depends what your after with the engine...if you just want it tuned a little better for the track I can do that for as low as $75.00, but if you want a full out crazy engine then that will run $125.00.. For the most part i get very good gains from just the $75.00 mod, my full out engines can sometimes be a handful to handle, but they are extremely impressive and will definitely get noticed wherever you run them..With altering the timing and flow I can tune the engine to suit your needs, so talk to me about what your after and we can work something out..I live in Winnipeg Manitoba Canada
No problem !
Old 09-27-2009, 10:54 AM   #70
yeh thats what i thought on the filter ....im with ya on the something better than nothing ..i was thinking a piece cut out of some panty hose...thinking you could just band it around the carb ...
LATER COOKIE
TEAM PROLINE-RACING
Old 09-27-2009, 12:39 PM   #71
Integra's Avatar
max seems to be forgetting the crazy fuel spittage with no filter.....when we first first ran the bench I didn't even bother with the stock plate and went right into fabbing what you see in the vid....i know its ghetto...but it works like a charm....you can sit it on the ground like in the video or place it on a table screw in the 2 screw's and it stay's put.....the motor mount's are from a old Jammin Pro as the RD mounts are JUNK and use the small 3mm nuts to slide it into place...imo its a joke...throttle is a savage 90 arm with a couple pieces of threaded rod and a return spring...works just like a servo........me and max are firm believer's in varying the throttle as in the video....sticking to 1 rpm for any constant time isn't the best if you ask me personally....we have had Extremely good luck with the bench and its easily seen over 100 motor's in the last 2-3 year's....the filter neck is some old 1/10 neck i found in my bin of old junk...the filter is a STS onroad filter we got from back in the STS days....1 thing that you can do is shim the prop out to clear more of the filter...but Be CAREFUL as if you shim it too far the threads will strip on the nose cone as there isn't enough threads to bit down and its only alum so it will strip...we've been through 2-3 nose cone's over the years.
on the fuel spitage thing...for some reason when there's no filter on the air over the carb inlet causes a vacuum and actually sucks the fuel from the carb and Splashes it on the block....i honestly dont know how some are working benches with out filter's...but that was 1 thing i remember in the very beginning and since using a filter everything is obviously bone dry after a run...Wrapping the head is also 10000% Critical...the air flow over the motor is Soo extreme that it WILL NOT allow the motor to run at proper temps and WILL pooch the motor in no time...I use tin foil first then a neoprene sock over top to keep the foil in place.
Old 09-27-2009, 01:44 PM   #72
good info man ..yeh i mean when ive been at the speed shop and been running them in ..i havent seen any spittage of the fuel like you were saying ..i gave alan a gmk engine koozie ..they sell em in packs of 3 ...if you wanted just take a regular can koozie and cut the bottom off ...when i first brought it over to him ..he said what is that for ...since he has just about worn it through they work like a champ and much better than foil ..and they stay in place really good ...me being 15 minutes from the speed shop ..i should prolly just take em there and let the man do em ...after he broke in my standard grp and i saw how the bench actually worked ..and how well it worked ..i told him i gotta have one in my shop .....and yeh im gonna find something to rig up for the filter for sure ...i like the way yalls comes off there ..and yeh it is hard sometimes to get that temp that prop puts off some sure enough wind power onto that head
LATER COOKIE
TEAM PROLINE-RACING
Old 09-27-2009, 01:47 PM   #73
heres the linky for that cylinder koozie ...gmk makes the best stuff ..stuff that really works ...inmho
http://www.amainhobbies.com/product_...eak-In-Sleeves
LATER COOKIE
TEAM PROLINE-RACING
Old 09-27-2009, 11:11 PM   #74
tristyn's Avatar
Default JPX.21
Ha if anyone has 2-3 gallons on the new + can you tell me what your run times are.
tristyn is offline   Reply With Quote
Old 09-28-2009, 03:31 AM   #75
Well guys I finished up the Ks. pro series rd.#5 today and moter ran great!Highest temp was 237 F. out side temp was about 90 .Have not tried to push run time since my main was only 30 min. My car was set up very very bad for my race had to fight the car the whole race and had 3 flame outs cause my idle was set to low.Still got 2nd. in the A and won the state championship in sportsman buggy.Going to put my old setup on this moter cause with msr1005 pipe and 1.1 clutch it is way to nasty for me!My old set up was 2035 pipe 0.9 clutch springs cut carbon shoes odonnell hot plug 30% nitro.This set up is very crisp bottom to top and smooth with good fuel mileage witch suits most of the tracks hear in Ks.. Our tracks tend to be med. size and low to med bite.I have ran a jp4 on these moters as well and liked it.Wont race nitro for a couple of weeks but will chime back in and try my old set.
What a Good 21 to get? Kausekaos Nitro Off-Road 22 08-28-2009 02:04 AM
Jammin JPX .21 heeltoedrver Nitro Off-Road 165 08-25-2009 01:02 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
*Beautiful Xray XB8* Karter01 R/C Items: For Sale/Trade 70 12-14-2008 03:55 PM
What is the best .21 buggy engine chris1381 Nitro Off-Road 30 10-28-2008 05:38 AM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
