Old 09-24-2009, 06:54 PM   #46
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by JUD View Post
Is this still a Picco based engine? I see the box is different.
yes
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 09-24-2009, 07:38 PM   #47
Maximo's Avatar
here is my engine break in
http://www.youtube.com/watch?v=VuP0H3Ot1lM
Maximo is offline   Reply With Quote
Old 09-25-2009, 07:27 PM   #48
Trader Rating: 29 (100%+)
ive got 10 picco P5TH plugs for this motor if anyone wants them. pm me and i will tell you what im looking for them.
kyosho mp9:novarossi 21-4C, nova 2084, 7955TG, dx3R
slayyer is offline   Reply With Quote
Old 09-26-2009, 09:04 AM   #49
8&stuff's Avatar
Trader Rating: 55 (100%+)
I have a jpx 21(not the plus). tunes great and runs even better. only prob is that it lean bogs at full throttle, for a couple seconds. I have a mach carb and see that some nova carbs fit and some dont but would rather keep it stock. the bottom needle slide is smoooth. i went around and sealed it everywhere, should that be good enouph? I did a search and seen that sealing should help although wondered if i should try anything else too. thanks for help.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 09-26-2009, 09:13 AM   #50
Maximo's Avatar
richen it up ? what plug are you using ?
Old 09-26-2009, 09:21 AM   #51
Integra's Avatar
If your referring to my Nova carb on my JPX in truggy...its an older all alum body that has been turned down on a lath to fit.
sealing might help...tho it might not pending what the problem is.
Old 09-26-2009, 09:22 AM   #52
8&stuff's Avatar
on the bottm will do. os p3. never ran any other so hope it isnt stripped
Mark Buecker
Old 09-26-2009, 09:23 AM   #53
Integra's Avatar
I think you already know our feeling on those plugs.
Old 09-26-2009, 09:30 AM   #54
8&stuff's Avatar
i described it wrong, its not a lean bog.
at full throttle it stays at full throttle for 2 seconds then go back to idle(carb dont stick). im gonna try richin bottom and if still does it il grab new button, ceramics and go from there.
Mark Buecker
Old 09-26-2009, 09:31 AM   #55
Maximo's Avatar
Does this issue get worse once the engine is fully warmed up ? I think I know exactly what is happening
Old 09-26-2009, 09:39 AM   #56
8&stuff's Avatar
its about 200 when i put on the track and then it happens.
Old 09-26-2009, 09:49 AM   #57
Maximo's Avatar
i will bet the seam on your carb is leaking....seen it happen many times...
however where is your needles settings ? and what pipe are you running ?
Old 09-26-2009, 10:02 AM   #58
8&stuff's Avatar
I normally seal every engine i get and didnt this one. i was running 086 with short header. switched it 2 tanks ago for 053 and long header for the indoor season. Any other pipe youd suggest? il seal the carb base and i have no doubt that this will resolve issue. if not il try different button.
Old 09-26-2009, 10:04 AM   #59
Trader Rating: 47 (100%+)
JB Weld, Lucky7, re-set LO and HI speed needles.
Hook him up Maximo (aka. Jammin-Picco Guru).
Gimme a call Neil.
rageworks is offline   Reply With Quote
Old 09-26-2009, 10:05 AM   #60
8&stuff's Avatar
top needle is right at flush and bottom has a small gap
What a Good 21 to get? Kausekaos Nitro Off-Road 22 08-28-2009 02:04 AM
Jammin JPX .21 heeltoedrver Nitro Off-Road 165 08-25-2009 01:02 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
*Beautiful Xray XB8* Karter01 R/C Items: For Sale/Trade 70 12-14-2008 03:55 PM
What is the best .21 buggy engine chris1381 Nitro Off-Road 30 10-28-2008 05:38 AM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
