Old 10-13-2010, 01:37 PM   #301
Jaz240's Avatar
Trader Rating: 52 (100%+)
http://www.nitrohouse.com/catalog/pr...ducts_id=12846
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 10-13-2010, 03:33 PM   #302
petevette's Avatar
Send a message via Yahoo to petevette
Hi guys, my JPX flamed out three times last weekend in the exact same place on the track - on the landing of a big jump. This just started recently. What could cause flameouts on hard landings?
petevette is offline   Reply With Quote
Old 10-13-2010, 04:15 PM   #303
Jaz240's Avatar
rocks hitting your flywheel
Old 10-13-2010, 05:46 PM   #304
Integra's Avatar
are you on power ? or just at idle ? or does it make a difference ?
Old 10-13-2010, 05:57 PM   #305
I would look into the flywheel and chassis clearance .
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Old 10-13-2010, 08:36 PM   #306
petevette's Avatar
I am not on power and I don't think it is rocks. I don't see any scraping of any kind where the flywheel meets the chassis. Can less then ideal compression cause this? The engine has been a champ, but it has some time on it. The compression feels border line when it is cold. Some folks say the compression is still okay, but others say the compression is low. I think the engine may just be tired.
What do you guys think, can it be a compression thing?
Thanks!!!!!
Old 10-13-2010, 08:49 PM   #307
jmaxey51's Avatar
i bet the flywheel is hitting the dirt, my dad and i had the same problem with our JPX over one big jump on the track so we switched engines and still had the problem and realized it was just hitting the flywheel, if we landed with some throttle it would stay running. so its probably that.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 10-14-2010, 04:27 AM   #308
Thanks!!!!!
Have you taken it out and ran it around the yard to see if it flames out around the same amount of run time ? If so I would think compression mite be a factor .
Old 10-14-2010, 05:06 AM   #309
I had this exact same problem at the GCS race at Augusta. I'll bet my chassis was grounding out on the dirt like you experienced- I just never thought about that. Your smarter than you look Johnathan
Brian
MiniMeRCRacing is offline   Reply With Quote
Old 10-14-2010, 08:38 AM   #310
petevette's Avatar
Good input guys. The first two times it happened were during the 5 min qualifiers. I raised the idle a click before the 20 min main an attempt to eliminate a low idle setting. Well 10 minutes into the main and all was good. I thought I was golden. Then with 4 minutes to go it flamed out again.
I am going to try to keep the back of the car from contacting the ground first by bringing down my front end right before landing. If the flameout is caused by clay/rocks hitting the flywheel bringing down the front end should help minimize the risk of it happening again. I am starting to think that the hard landings may have been with the chassis flat or even landing the back of the car first. Lets see what happens this weekend. Thanks guys!
Old 10-14-2010, 01:09 PM   #311
nitroexpress's Avatar
Thanks!!!!!
Check the rod. Even though it's an Italian engine, the rods tend to checkout early.
nitroexpress is offline   Reply With Quote
What a Good 21 to get? Kausekaos Nitro Off-Road 22 08-28-2009 02:04 AM
Jammin JPX .21 heeltoedrver Nitro Off-Road 165 08-25-2009 01:02 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
*Beautiful Xray XB8* Karter01 R/C Items: For Sale/Trade 70 12-14-2008 03:55 PM
What is the best .21 buggy engine chris1381 Nitro Off-Road 30 10-28-2008 05:38 AM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
