Old 02-22-2010, 05:54 PM   #211
RJSI's Avatar
Originally Posted by Quad Racer 34 View Post
ive seen many people run the jp3 and they have had great success with it
I ran the JP3 this past Sunday, and was a ripper. But at some point I either was too lean or wayyyyy too rich on the bottom cause I had no take off. I just couldn't figured out. I open the LSN way out and still had issues. Then I noticed the gasket of the manifold was broken, and thought, perhaps an airleak that wont let it resonate back to the engine full. But no, change all fuel lines, check the carb... just couldn't figured out.
Also, what's the cure for sticking carbs?
RJSI is offline   Reply With Quote
Old 02-22-2010, 06:00 PM   #212
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by chris1381 View Post
Post back your results with that set up. That is what I have and I am going to run 20 % fuel but I haven't broke the motor in yet .But I would like to know what run times you are getting and what setup you were using and what run time if you don't care to share. Thanks
ok i tested my setup saturday at a indoor track and i was getting around 7:30 - 8 min each tank. i love the 086 pipe. much better than the 053 imo.
after my gallon of 20% fuel im switching to 25%
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 02-26-2010, 03:21 PM   #213
RJSI's Avatar
What's the cure for sticking carbs?
Old 03-08-2010, 07:10 AM   #214
RJSI's Avatar
This past weekend had a great race day. The Jammin just broke in and it really woke up some higher RPMS and torque I haven't seem in it.
Out and about today helping a friend to move; after being done I decided to go and race.
Missed the first qualifier cause I was running late; so after the second qual I was already in second placed. Cool I said, with 14 Truggys runing I wanted to be ahead of the pack and not get caught in traffic on the main.
Amain - I am in second place knowing I can take the leader and pull away on the first turn; race started and exactly as I predicted the leader went wide on the first turn and I just turned in under him and he never saw a chance to win that first spot again.
Knowing that I am now vulnerable to my own mistakes I decided to pit the 30 min main away from the pack and the pit lane traffic; so I pushed the 9 min mark on both pit stops.
My pit had his skill dialed and got me going in less than 5 seconds.
My JPX .21 plus was perfectly dialed and was pulling away from two OS speeds an Alpha, 2 Reedy's and an) WS7. Long story short as this was a Money race with a purse of 150 at stake I took home the win. However the owner is building a new track and since he put together this race and allowed me to enter late I donated the money back for the new track. Needless to say, owner offered me to pick any 1 item I needed, so I stocked up on glow plugs and took home the bragging rights jjajajaj
That's it for now, the 6T is meanly dialed and the Jammin JPX is a keeper and a new one is already on its way to me. Great engine, just under estimated.
Old 03-08-2010, 07:15 AM   #215
Maximo's Avatar
+100 awesome engines, and faster then 99% of of the other offroad .21's....
Maximo is offline   Reply With Quote
Old 03-08-2010, 07:46 AM   #216
RJSI's Avatar
I was about to drop $354 on a Ninja... but no forget it. This is very good engine just way under estimated by many. Some say it takes too long to warm up on cold days, others just don't know how to really get a good matching pipe.
I am really pleased with the results. I have both, the PLUS and the older version as a spare.
Old 03-08-2010, 08:32 AM   #217
petevette's Avatar
Send a message via Yahoo to petevette
That was a classy thing you did with the purse. Not many people like that.
My Jammin is awesome. I haven't touched the needle in weeks and it idles forever, screams on the track and never temps over 240.
petevette is offline   Reply With Quote
Old 03-08-2010, 10:21 AM   #218
tristyn's Avatar
Default Jpx.21
I ran the jammin engines a few yrs. ago and realy like the engines. The last couple of yrs I ran the GRP TUNED engines. I am getting ready to purchase a couple new engines for this season and am considering buying the JPX.21 PLUS. Correct me if I am wrong, The 086 pipe with 1.0 springs is the set up for this engine? Oh ya I will be running this in truggy. Also what venturi size and what is the average run time? Seems like the old JPX. only ran aprox. 8-8 1/2 min. I currently own DYN 053, 086, JP3, JP4 would any of these pipes be suggested as the best for this engine?
tristyn is offline   Reply With Quote
Old 03-08-2010, 11:55 AM   #219
i would use the 086 pipe and 1.0 springs. i think thats the key for this engine. mine runs great with that setup. and a 7mm carb insert. i can get 7:30 to 8 min in my buggy. good enough for me. this engine is awesome!
Dylan Gerard
Old 03-08-2010, 12:18 PM   #220
petevette's Avatar
+1. That is exactly my set up and it runs phenomenal.
Old 03-08-2010, 12:31 PM   #221
sicsam's Avatar
this is what im going to run on my 2.0 truggy but im using losi clutch and what type of clutch setup should i use for it?
Battlefield R/C
sicsam is offline   Reply With Quote
Old 03-08-2010, 12:34 PM   #222
sicsam's Avatar
Originally Posted by Integra View Post
you wont be disappointed with a clocked JPX....I cant guarantee that.
Cant guarantee? :weird im jokn...
Battlefield R/C
Old 03-08-2010, 03:31 PM   #223
Integra's Avatar
Truggy try Gold on all 4 and if it hits a little too hard work your way down starting with 2 green then all 4 green.....As other's have stated this motor pulls HARD on bottom so i would doubt anything higher then gold will be required.
Old 03-08-2010, 03:32 PM   #224
Integra's Avatar
wow...never saw that....that kinda sucks for anyone reading....lol....ill be fixing that asap....plz fix the quote if you could Plz and thx.
Old 03-08-2010, 08:04 PM   #225
tristyn's Avatar
Default JPX .21
So best run times are 7:30 - 8 min.?
What a Good 21 to get? Kausekaos Nitro Off-Road 22 08-28-2009 02:04 AM
Jammin JPX .21 heeltoedrver Nitro Off-Road 165 08-25-2009 01:02 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
*Beautiful Xray XB8* Karter01 R/C Items: For Sale/Trade 70 12-14-2008 03:55 PM
What is the best .21 buggy engine chris1381 Nitro Off-Road 30 10-28-2008 05:38 AM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
