Old 02-04-2010, 07:10 AM   #166
Send a message via Yahoo to windellmc
Amain also has those restrictors.
I had to replace the rear bearings on both of my JPX engines. I used the TKO ceramic bearings (should be the same size as the Vspec bearing) and they have worked great ever since. First engine last a couple of gallons and the 2nd engine barely made a gallon. Both have ran a few gallons since then with no issues.
I am convinced I had a fuel problem since both bearings went at the same time although one engine was six months older. What fuel are you running?
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 02-04-2010, 07:24 AM   #167
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Originally Posted by petevette View Post
Hi guys, I have about 2.5-3 gallons through my JPX Plus. The engine runs awesome, but last night I heard the main bearing. I am going to order a TKO replacement bearing for it, but wanted to get your input. Is a ceramic bearing better for this application or just a standard bearing?
Also, has anyone else had to replace the main bearing and if so, how many gallons did you have through it?
i replaced both bearings after about 3 gallons. thats when i saw that the front bearing was starting to leak. so went ahead and replaced both of them at the same time. they helped a lot. TKO ceramics by the way.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 02-04-2010, 08:13 AM   #168
petevette's Avatar
Send a message via Yahoo to petevette
Interestingly enough, I am running Maxy fuel. He was at the track last night so I got his input and he confirmed it was the main bearing and said it is because I leave fuel in the tank between races. I race, at a minumum, weekly so fuel never sits longer then 1 week. He said that is all it takes.
Other experienced racers say that has nothing to do with it, but Maxy knows fuels so I am not sure what to believe.
My front bearing seems to be okay. Do you guys think it needs to be replaced too? I rather not touch it unless it is really the smart thing to do. I will inspect it once I disassemble the engine but do you guys always replace both or just the one that is bad?
Thanks for the input guys.
petevette is offline   Reply With Quote
Old 02-04-2010, 08:27 AM   #169
When you take the engine apart you can check both bearings. Replace them if they fell rough or have play between the inner and outer races. I am still on my original front bearings. Only the rear bearings went bad. I was running Byron's gen2 at the time and everyone was having rear bearing issues on that fuel around here at the time. The fact that I had two go bad very close together not long after switching to the Gen2 tipped me off.
I also have a Vspec that had a front bearing go bad and the rear is still good so it is worth it to check. I have never run Maxy's fuel and since you got 3 gallons on the original bearings it is probably ok fuel. I run OD fuel now, and I am not sure you can beat it for wear protection.
MP9 tki4
Truggy?
Old 02-04-2010, 02:30 PM   #170
another question..
do i need to remove or add any shims to this engine if i run 30%? i run 20% now and have one shim in it now i think. or whatever comes in it stock.
thanks
Dylan Gerard
Old 02-04-2010, 02:49 PM   #171
jmaxey51's Avatar
Add one more shim and you'll be set. If you don't and run 30% it will die quick it might not last two more gallons. I have seen people not add a shim and theirs made it about 2 gallons.
jmaxey51 is offline   Reply With Quote
Old 02-04-2010, 02:56 PM   #172
RC-ZOMBIE's Avatar
My JPX has 3 shims in it stock and 1 extra for 30%
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
Old 02-04-2010, 03:21 PM   #173
Maximo's Avatar
you do not need to add a shim to run 30%...LOL..I actually remove 1 shim and run 30% and my engines last just fine !!!
Maximo is offline   Reply With Quote
Old 02-04-2010, 03:23 PM   #174
ew lol i think ill add another
thanks
Dylan Gerard
Old 02-04-2010, 03:32 PM   #175
My manual say's to add 1 shim .01 mm in thickness to run 30 % But from what i have heard maximo knows this engine . I have talked to a few people who said the engine only lasted a couple gallons & the common factor is they were running 30 % without adding a shim . Mine is just starting the fourth gallon & other than a leaky front bearing i have had no problems . I run 20 % with stock shimming . Hope i'm not jinxing myself LOL .
romax is offline   Reply With Quote
Old 02-04-2010, 03:38 PM   #176
uhhh yea i think im just going to stick with 20% for this engine lol
or wait.. would switching to 25% need any shims?
Dylan Gerard
Old 02-04-2010, 05:11 PM   #177
jmaxey51's Avatar
im pretty sure the manual says that you can 25% with stock shims but im not 100% sure so if you have the manual look threw it and it will give you all the info.
Old 02-04-2010, 05:17 PM   #178
ok ill try to find it. thanks for all the info
Dylan Gerard
Old 02-04-2010, 05:25 PM   #179
I run 25% in my stock Jammin no problem at all, Listen to Maximo he knows these engines .
nothin special is offline   Reply With Quote
Old 02-07-2010, 05:35 PM   #180
petevette's Avatar
Can someone please confirm the size for the main bearing? I am looking at the Amain website, but don't see it listed. (DISREGARD, JUST FOUND A POST WITH THE SIZE. THANKS!)
Thanks.
What a Good 21 to get? Kausekaos Nitro Off-Road 22 08-28-2009 02:04 AM
Jammin JPX .21 heeltoedrver Nitro Off-Road 165 08-25-2009 01:02 PM
v-spec vs jpx.21 engine comparison Bulldawg RC Nitro Off-Road 36 04-23-2009 09:16 AM
*Beautiful Xray XB8* Karter01 R/C Items: For Sale/Trade 70 12-14-2008 03:55 PM
What is the best .21 buggy engine chris1381 Nitro Off-Road 30 10-28-2008 05:38 AM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
