Old 08-29-2009, 03:26 PM   #1
Default can motor be fixed?
i killed my axe cobra x1 as i see metal shavings inside. Can it be saved? i have another piston sleeve and conrod but what else would i need? The inner walls have been damaged not sure what you call it? Any help would be appreciated as i am a complete moron!
thanks
roots is offline   Reply With Quote
Old 08-29-2009, 03:31 PM   #2
thanks
Can you post a picture of the inside of the motor from the top and from the rear plate?
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 08-29-2009, 04:23 PM   #3
Sounds like rear bearing is going out or maybe the connecting rod bushing.
bigde2001 is offline   Reply With Quote
Old 08-29-2009, 06:58 PM   #4
cluffy1's Avatar
i have just blown up my Axe rossi Cobra X1 As well but it was just the conrod that must be replaced.
if the sleeve is damaged you mite have to buy a rebiuld kit for it. this is the cheapest way to get the engine running with having to buy a new motor. check all bearings and other componense for damage as well. may be better off getting a new one. easest way to check if bearings are buggered is to wiggle the cranks shaft if it moves side to side it is buggered.
hope this helps
dane
go hard or go home
cluffy1 is offline   Reply With Quote
Old 08-29-2009, 07:15 PM   #5
22Racer's Avatar
Trader Rating: 67 (100%+)
It depends on what the shavings are from, I charge $35.00 to rebuild a motor. If I take it apart and it is not fixable all you are out is the shipping.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 08-30-2009, 06:47 AM   #6
pics to come
MurfDogg Motor Works Discussion thread The MurfDogg Team and Company Discussions 1382 12-08-2014 05:38 PM
Silver Can Motor Tips/Tricks TAMIYAMANUK Electric On-Road 1741 04-11-2014 01:44 PM
Mamba Monster V3 2200KV Motor and ESC hound_dogs_01 R/C Items: For Sale/Trade 7 06-29-2009 04:28 PM
Traxxas Velineon ESC and Motor combo everyjuangohome R/C Items: For Sale/Trade 15 01-09-2009 10:31 PM
Servo Motor Comm Cutting LMB Nitro Off-Road 22 01-03-2009 10:52 PM
