Old 10-09-2009, 08:51 AM   #91
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by sugs View Post
Hey Jimmy, are either you or Chris going to be at ARC Saturday?
I'm going to try to be there. I have mucho engine break in/testing to do.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 10-09-2009, 08:53 AM   #92
Originally Posted by itsshemp View Post
Jimmy/Chris- Congrats on everything. It looks like things are taking off well for you guys! That is great!
Im glad to see that you guys are distributing the new Alfa engines. I was impressed on Danny Choi's finish with this engine last weekend. I will be looking into one of these soon, and will most definitely be contacting you guys about one.
Keep it up!
Danny Flores
Thanks Danny!
Yes we were impressed with it's performance in Dani's buggy as well as Tony Rosales' Truggy.
Jimmy
Jimmy Wright
Old 10-09-2009, 08:56 AM   #93
Originally Posted by Euro Stealth View Post
These Alpha motors are looking pretty gnarly, can't wait to order mine monday =)
Thanks Brandon!
Jimmy Wright
Old 10-09-2009, 08:57 AM   #94
Euro Stealth's Avatar
Your welcome sir "Old Man"
Brandon Ryan:
Thank you!
*The Speed Shop*JConcepts*Blue Groove Apparel*Kustom RC Graphics*
Euro Stealth is offline   Reply With Quote
Old 10-09-2009, 08:59 AM   #95
OH! I see how it is!.....
Jimmy Wright
Old 10-09-2009, 09:02 AM   #96
Dude if "Big Daddy" knows you on a first name basis.... I'm just saying
Brandon Ryan:
Thank you!
Old 10-09-2009, 09:11 AM   #97
sugs's Avatar
Sending PM.
- Associated B4.1 Worlds -
- Associated SC10 FT -
- Associated SC10 4x4 -
- Mugen MBX6 Alpha F850 -
- Nomadio Sensor - Hitec servos - Panther tires - DE Racing -
sugs is offline   Reply With Quote
Old 10-09-2009, 09:18 AM   #98
He knows my parents mostly. Both my parents were drag racers back in the day. 55-72
My Mom got to know Don after her first husband was killed at Lions in 66. Don and Pat were a huge help for her as were many other "names" of the day as you could imagine.
Jimmy Wright
Old 10-09-2009, 09:32 AM   #99
true true, yea he's good people. He helped my dad at Gainseville when he was running his Nova on a test-n-tune day.
Brandon Ryan:
Thank you!
Old 10-09-2009, 06:13 PM   #100
That right there just made that Nova worth DOUBLE!
Jimmy Wright
Old 10-09-2009, 07:06 PM   #101
OK Y'all.
First impressions of the Alpha Plus engines.
Upon tear down I noticed the same on both of the engines I'm working on so when I'm explaining I mean for both.
Tear down went smooth. I noticed tight tolerances on all machine work and assembly was done for these engines to be ready to be fired up for break in.
Pulling the cooling head off I noticed the head bolts are a whopping 3.5mm (NICE!) These will help in keeping things sealed very well.
Upon removing the back plate I noticed here that the oring was actually tight enough to hamper removal. (another nice! as this will help with sealing)
Upon further inspection the engine is well lubed in a very light machine oil. Most engines I've seen you are lucky to have anything other than bearings lubed. Also in that oil and throughout the case and parts I found no slag, slivers or shavings of any kind. (Something you usually find here or there in any engine) and the cases are bur and flash free.
Removal of the carburetor was also a bit tight even with the pinch bolt removed. I found no body distortion and the slide is so free youd swear it was on roller bearings. The boot is average but seems thick enough not to tear under normal conditions. It fit tight around the carb and the slide.
The carb throat has double orings so one bit of advice if you pull one off make sure you push it all the way down to seat it in the second o ring.
Another huge plus I found was their use of SKF (Italian made) bearings!
The front bearing is actually double sealed. (Another NICE!) for sealing purposes.
Some cool features I found also were the milling of the case, in the sleeve bore, right behind the locater pin for the sleeve. This IMO was to relieve any swell that may happen to the case bore when the locator pin is pressed in.
Also the engine comes with header gasket, dust plugs, a flywheel collet and a bolt in the crank snout for the clutch. AND...... comes with 7 (blue), 8 (green, in engine) & 9mm (red) inserts
Going through this stage I give it 5 out of 5 "Track" Stars.
Jimmy Wright
(Next stage is break in)
TRACK STAR RACER SERVICES NOW OPEN (SoCal)-alpha-engines-004.jpg   TRACK STAR RACER SERVICES NOW OPEN (SoCal)-alpha-engines-008.jpg   TRACK STAR RACER SERVICES NOW OPEN (SoCal)-alpha-engines-009.jpg   TRACK STAR RACER SERVICES NOW OPEN (SoCal)-alpha-engines-013.jpg
Jimmy Wright
Old 10-09-2009, 07:18 PM   #102
RC Pro 1's Avatar
Hey your camera is almost as fuzzy as mine!
I'm glad you posted all that Jimmy I noticed a lot of nice stuff when I tore down the F850 but I think more people would listen to someone who works with engines all the time than me.
RC Pro 1 is offline   Reply With Quote
Old 10-09-2009, 07:21 PM   #103
My iPhone camera doesn't get too close. My wife keeps the good camera in the "Horse bag" just incase he does something "cute".....
Seeing is believing and so far I like what I see.
Jimmy Wright
Old 10-09-2009, 10:13 PM   #104
MMMM looks and sounds delicious! Can't wait to hear about the Break-In, and rest of the first impressions blog you are putting together!
Brandon Ryan:
Thank you!
Old 10-10-2009, 06:47 PM   #105
Keep this on the first page for Step 2 of the Alpha Plus motor blog of Jimmy Wright.
Brandon Ryan:
Thank you!
Prime Fuel now available in SoCal. Racecrafter Nitro Off-Road 18 04-17-2010 01:33 AM
