Old 08-28-2009, 09:55 PM   #1
Dannn's Avatar
Default TRX 3.3 got a wee bit warm
It got over 300 i know for sure... maybe 310-320. It doesnt have much pinch left... i was having a hard time tuning it even over 4 turns out. I couldnt keep it running right.
Think its still okay? With the glow plug it has a bit of resistance.
I wanna know before i try running it again.
Dannn is offline   Reply With Quote
Old 08-28-2009, 10:05 PM   #2
I never got more than 4 gallons from the 2.5's.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 08-28-2009, 10:07 PM   #3
Dannn's Avatar
the thing is... this has about less than a quart thru it since i've had it. it ran great one day, then terrible the next. i took the head off and the piston was silver... i bet it doesnt even have a gallon thru it.
Old 08-28-2009, 10:12 PM   #4
Bring it back to stock settings. Set the idle gap back to 1mm and then try to start it. You'll have to, more than likely, lean the low speed needle until it starts. Then you can tune the high speed to get top end power. You will hten notice that the motor ill rev high at idle. Richen the low speed till it idles low, but still rips off the line.
If the motor revs on at the end of a high speed pass the high speed is to rich, if the motor revs on while bilpping the throttle trough corners then the llow speed is lean
Once it runs right, the temps will be what ever they are.
Old 08-28-2009, 10:30 PM   #5
Dannn's Avatar
alright i'll try that. thanks for the info.
i liked the way it was tuned the day i got it... it would go about 15-20 minutes on a tank and run a consistent 240 degrees. oh well... i'll try tomorrow. i have to convert the revo back to nitro.
Old 08-28-2009, 10:33 PM   #6
If the weather changed the motor cold have been running lean.
I don't think running it lean once would hurt it.
20min on a tank How big is that tank?
Old 08-29-2009, 10:02 AM   #7
Dannn's Avatar
stock tank. this is the second revo i've seen do this... my friend had a 3.3 in the ext. revo and he got 20-25 minutes on his tanks... bashing. then again i dont do WOT runs over and over... i drive around and hit little jumps
Old 08-29-2009, 12:02 PM   #8
backwoodsRC's Avatar
Trader Rating: 23 (100%+)
Send a message via Yahoo to backwoodsRC
Default air leak?
look for air leaks.. may have a lot to do with tune issue.. and high temp..
www.backwoodsrc.com for RC Truck and tractor pulling in Middle TN.
Find use on Facebook Backwoodsrc pulling team of TN
backwoodsRC is offline   Reply With Quote
Old 08-29-2009, 01:03 PM   #9
losi_racer's Avatar
Trader Rating: 25 (100%+)
15 is believe able just doing what your doing but 25 is pushing it. he must of been walking faster then that was driving
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 08-29-2009, 04:31 PM   #10
Dannn's Avatar
well i got it all together today... it started, ran and was running very very rich. it still revs like crazy. so i dont think its burnt up. the temps ranged from 190 to 260 while trying to tune it. failed attempt though, i'm gonna try again tomorrow when i have more time.
Old 08-29-2009, 04:33 PM   #11
Sounds like it may be running lean. I temp pointing down directly at glow plug to get most accurate temp.
bigde2001 is offline   Reply With Quote
Old 08-29-2009, 08:38 PM   #12
Dannn's Avatar
no i'm talking about top end sorry... saying it still revs out to the rpms its supposed to hit. i sealed the crank case and carb up. the idle is a bit off and varys... sometimes it bogs right after idle and dies... its all in the tuning i think. i put a new trx 2.5r carb on there hoping that would help. it did quite a bit.
