Old 08-28-2009, 09:44 PM   #1
Default Troubles Running my engine.
Hello everyone. I recently purchase a nitro rc truck off a buddy, took it to my local rc shop and toldthem to hook me up with some things i needed.
I purchased a glow plug igniter, which seems to be working fine, i can get my engine started, it will run, ive adjusted the idle and such, im not sure if it is because the car is new, but when i take the igniter off, at first it only would idle for about 30 seconds and would quit without warning, now its lasting a minute or two, and still quits without warning, no change in idle, just like someone hit the kill switch.
if i move the throttle and keep it running, it will stay running.
also, when moving the throttle, a spray of gas or liquid comes out of the exhaust along with some blue smoke, is this regular?
any advice would be greatly appreciated.
EDIT: ive also been through almost 2 tanks of gas, running at about idle speed, sometimes throttling up and down to keep it going.
justkeats is offline   Reply With Quote
Old 08-28-2009, 09:52 PM   #2
Cory Kerber's Avatar
You should lean your low speed needle an hour or two. That's the screw adjustment on the end of the carb boot area.
EDIT: Lean your LSN don't richen it. My mistake.
Losi 8ight-Novarossi N21R-Hitec Servos-AKA-M11 Spektrum
*TEAM TERRIBLES*
Cory Kerber is offline   Reply With Quote
Old 08-29-2009, 12:42 AM   #3
Read the tuning bible at top of page & that should give you a clue wich way to go but it sounds too rich to me,at least on the main needle but who can say without being there & trying a few quick things.You should have some smoke but not a lot & you should have a little oil spray if you have let it idle for couple minuits you talked about its just the unburned fuel/oil building up in the pipe as these little motors are not designed to run efficiently at idle. They have a narrow rpm range that they were designed to pump correctly at,like 18,000-35,000 rpm & some will still spin up to a little over 40,000 rpm. Just for reference it may not sound like it but they idle in the 3,000-5,000 rpm range & make almost no power till after 10,000-15,000 rpm.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 08-29-2009, 12:07 PM   #4
backwoodsRC's Avatar
Trader Rating: 23 (100%+)
Send a message via Yahoo to backwoodsRC
Default +1 way rich..
yea it sounds rich to me as well.. veri the glow-pug is correct for the engine.. what fuel and plug and engine combo do ya have
www.backwoodsrc.com for RC Truck and tractor pulling in Middle TN.
Find use on Facebook Backwoodsrc pulling team of TN
backwoodsRC is offline   Reply With Quote
Old 08-29-2009, 12:48 PM   #5
byron race fuels, gen 2
as far as the engine goes, team infinity 18.. i have no clue if thats right but thats what it says on it.
im very unfamilar with these race engines.
and glow plugs im not sure either, how can i tell?
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
MAJOR Engine troubles (i think...) new to rc cars Nitro Off-Road 33 04-16-2008 11:53 PM
Need some help memphis212 Monster Trucks 20 05-07-2007 12:44 AM
Engine Troubles PLZ HELP!! Hoggy Nitro On-Road 6 06-27-2005 10:43 PM
