Old 08-28-2009, 02:28 PM   #1
Default Difficulty starting engine
So I've been having trouble getting my Savage XSS going the past couple days (recently got it finished). I took it to the LHS and they were able to get it going and decently tuned, at least enough for me to tweak it and figure out on my own.
The problem is 90% of the time I can't get it cranked, or it will start up and die the moment I let go of the pull cord. This is after the LHS gets it going and everything works perfectly. I take it home, don't even touch the settings, and it won't start.
I'm going crazy because it doesn't run perfectly cause it needs tuning, but I can't tune it because 90% of the time it won't start.
I need some ideas on what to look for since this is my first nitro rc car and I'm pretty much a newbie.
Jeimuzu is offline   Reply With Quote
Old 08-28-2009, 02:54 PM   #2
increase your idle a touch, that might keep it runing long enough for you to get your hand on the remote...
tommo is offline   Reply With Quote
Old 08-28-2009, 04:11 PM   #3
I developed a technique of holding the radio and opening the throttle a bit while cranking it, which helps sometimes.
Though with adjusting the idle, am I gonna have to adjust it each time I start it ? When it does run, the idle it's set at is great. Just low enough to not engage the clutch and have it drive off.
The guy at the LHS did say sometimes you have to start new nitro engines with a little open throttle for a bit, but that didn't even work this go round.
Old 08-28-2009, 08:00 PM   #4
bump
Old 08-28-2009, 08:06 PM   #5
Try priming it. I hold my finger on the end of the exhaust pipe and pull the pullstart 3 or 4 time to get the fuel going to engine. Hope this helps.
bigde2001 is offline   Reply With Quote
Old 08-28-2009, 08:52 PM   #6
I know nothing about a savage but our local hobby shop always uses thier glow igniter. If you continue to try and start an engine witth a dead or partially charged glow igniter than you take a chance of fouling the plug. A fully charged igniter will usually burn the fuel off and the engine will run. Try to use a different igniter eben if it comes with a wire on the top of the motor. If the engine runs at the hobbyshop then it should start and run at your house. Unless the hobbyshop is ysing different fuel then what you hae at your house, if so buy some new fuel, good luck.
CONNARD is offline   Reply With Quote
Old 08-28-2009, 11:47 PM   #7
Thanks for all the replies. However, I just about always prime the system, and as far as igniters go, I charged mine up just the other day, and the fuel we use at the shop is what I have at home.
Old 12-30-2009, 02:57 PM   #8
nevermind
team driver for; | KO PROPO | NOVAROSSI USA | BYRON FUEL | BOCA BEARING | FASTLANE GRAPHIX |
T/E Maxx Thread Modena AL Monster Trucks 619 05-19-2014 12:30 PM
Punggol Off-road Track. Superb Singapore R/C Racers 9453 02-24-2010 09:26 PM
Monster Trucks! sidewayz Singapore R/C Racers 579 11-30-2009 05:16 AM
RB Concept C6 BBT7 for sale & L2G magnesium head separately jaylude22 R/C Items: For Sale/Trade 11 03-25-2008 03:22 PM
Problem with starting engine - Pull start Aceboy Electric Off-Road 17 05-02-2006 03:52 AM
Blogging engine rko Nitro On-Road 8 08-04-2005 04:27 PM
