Old 08-27-2009, 08:40 PM   #1
Default preheating Nitro engine
is 230 to high? I say that because i heat through the cooling head and the block only gets to 150.
i plan on always heating it up. Is that ok?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 08-27-2009, 08:46 PM   #2
At head that is not too hot. At base of head temping from side should around 160-180. Hope this helps.
bigde2001 is offline   Reply With Quote
Old 08-27-2009, 08:52 PM   #3
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
Thats good for heating, thats enough for the sleeve to expand a little for easy starting.
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 08-27-2009, 08:52 PM   #4
jhipps835's Avatar
Trader Rating: 13 (88%+)
You should definitely focus on heating the top end of the engine block so that the piston gets hot as well. I usually heat up both sides. But it should work as well from the cooling head. And the temp depends on your engine. I started at 200-210 then if it wasnt enough to start the motor i raised the temp until it started.
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-27-2009, 09:19 PM   #5
dreaux dreaux dreaux......
Your thinking about everythign wayy too much. Just run the car!
The cooling head isnt where the piston expands, it expands in the crankcase. For breakin, I have my heat gun on the head, but I check temps on the case and go for around 200. Generally the temps come to about 300 degrees on the head. I heat the head because if you head the block up you will heat it on 3 out of 4 sides, the side that wont get as hot is the carb side since you arent suppose to preheat the carb. Thats why if you heat the head up the heat is even so one side of the pistons isnt cold and the other side at 200 degrees.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
RB Concept Engine Thread dremelboy Offroad Nitro Engine Forum 565 01-21-2012 01:16 PM
Is it really hard on a engine to run in cold temps? hobdog Nitro Off-Road 39 12-21-2008 12:25 PM
engine break in mjnp06 Nitro Off-Road 19 11-17-2007 09:33 PM
How to properly tune an engine for on-road racing, edwintklee Nitro On-Road 31 08-26-2007 06:10 AM
Rossi Pixy Black R12 Motor FAST! FS/FT *PICS* LKracer R/C Items: For Sale/Trade 8 04-06-2003 10:30 AM
