Old 05-11-2010, 10:22 PM   #16
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
One of the RC magazines that just came out this month had an article of how to build your own break in bench...sorry I can not remember which one it was though.
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 05-12-2010, 07:50 AM   #17
Here is my Hudy stand with some "changes" I made
and a vid breaking in a Clockwork Racing Picco .28
http://cs2k.ca/HudyBreakIn.wmv
I now have a Competition Heat Engine Warmer which solved the "prop cooling issue"
Jed the Geezer is offline   Reply With Quote
Old 05-12-2010, 08:28 AM   #18
trevor15308's Avatar
Send a message via Yahoo to trevor15308
Originally Posted by mrbusta View Post
no fan or what do u put on ur motor for load as that wouldnt be good free spinning
just put the clutch and clutch bell
AGAMA RACING-TKO BEARINGS-AIRTRONICS-SIDEWINDER-WERKS-PROLINE-VP PRO USA-RCrenew.com
trevor15308 is offline   Reply With Quote
Old 05-12-2010, 09:48 AM   #19
thenova70ss's Avatar
Trader Rating: 52 (100%+)
I would like to see a Video of some one Braking in a Motor from the Fist Tank and up to the Last just Brake it down to a Couple of Min a Tanks that way it don't take a Hour to watch the Video . I wont to see how you guys Very the Throttle from Tank to Tank.
CHRIS CREWS
Pro Speed Racing Optima MX1 Buggy http://www.global-hobbies.com.my
Cold Fusion R/C Products Team Driver - www.coldfusionrcproducts.com
Rc Pro ProDucts Team Driver www.rcproproducts.com
Hobby Pro USA Team Driver www.vp-pro-usa.com
thenova70ss is offline   Reply With Quote
Old 05-12-2010, 10:46 AM   #20
I'm hoping to brake in an OS Speed this weekend ... I will put something together for ya ... keep in mind there are different brake in methods but I use the heat cycle method ... first 2 tanks at pretty much idle to seat the bearings ... then add some throttle each tank after that ... always nice and rich ... I will usually do 7-10 tanks on the bench then it goes in a truck
Old 05-12-2010, 01:53 PM   #21
COOL THANKS Jed the Geezer that is the kind of Video i have been looking for. I just wont to see how other people brake in motors on the Brake In Stands i am gone to get a motor stand in the next couple of weeks and would like to see how to do it i have all ways done it in my buggy but it takes up to much time having to drive the buggy around and be with it all the time with a stand i can just put in on there and do other stuf as it runs.
CHRIS CREWS
Old 05-12-2010, 06:12 PM   #22
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
yea thats no load i could really see that thing not good for the motor im no expert but u need load or bad things could happen especially in break in
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 05-12-2010, 06:28 PM   #23
i agree with you busta. But how much do you think that plastic prop actually weighs?
Is it slugged with weights or something? If not, it cannot weigh more then a flywheel, shoes and bell
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 05-12-2010, 06:38 PM   #24
mrbusta's Avatar
yip thats not i was refering to champ its the fact wen it spins it puts load on the motor but u can spin a motor with only a clutch assemble on then there is no load its what is refers to free spinning
81/MUGEN Mafia
RIP BUSTA BB ANGEL
Old 05-12-2010, 07:02 PM   #25
Trader Rating: 47 (100%+)
It's not about the weight of the prop. The prop blades have alot
of pitch on them and it puts alot of load on the engine. The faster
it spins the more the load increases to pull more air through the blades.
That's the reason for a shield in front of the carb. That much air
makes it hard to control the engine temps and without an air cleaner
of some kind, the fuel gets pulled out the venturi a high rpm's.
rageworks is offline   Reply With Quote
Old 05-12-2010, 07:02 PM   #26
we are talking about the same thing. I know you cannot run a motor without the tires on. I already know that. what i want to know is how much the prop weighs. Because really it only matters when you vary the throttle. Since the clutch is disengaged.
So i guess the real question is, does the break in bench have a load on it ALL THE TIME. Not just when the clutch engages.
OR
Is there a flywheel/clutch that engages the prop?
if there is a load on it at ALL times then even in your buggy you would have to have a big ass flywheel to equal that. Or you would have to have a high enough idle to engage the clutch at all times, which would not be good for the engine.
low and varied rpm's with load at all times. Sounds like a winner
wait i understand now. The prop creates load from air resistance on the fin fan.
well crap. Strap a propellar to a stand and break the sucker in!
Mugen
Old 05-12-2010, 07:28 PM   #27
dreaux, the prop is mounted soild onto the engines
crankshaft using a special adapter. Yes, there is always
some load on the engine, at all times, when the engine
is running. The engine is never allowed to freewheel with
out a load on it.
Old 05-12-2010, 07:45 PM   #28
RD Logics also makes a break-in bench and sells
the parts for it. You can buy the prop, prop adapter
and prop nut from them and build your own bench,
set up the way you want it. Here is the link,
http://www.rdlogics.com/cgi-bin/cate...tegory=Engines
Old 05-12-2010, 07:52 PM   #29
I have used that 1 for a few years now. Works like a charm; bought mine on e-bay cheap. I have a nova motor ready to go when I get a free weekend and along with a comp engine heater it should all the way
jet flyer is offline   Reply With Quote
Old 05-12-2010, 08:09 PM   #30
thanks for the link. That was really cool.
huddy makes great stuff no doubt, i do have thier set up station. But i don't think all that is necesarry for everything. I do think the set up station is a bit overkill. But it does work great
Mugen
