Old 08-25-2009, 08:22 PM   #1
gixxerman's Avatar
Default Exhaust Gas Cooler Opinions
I recently tried a RB exhaust gas cooler on my WS7 with some horrible luck! My motor was never more than a hour or two off from week to week and was completley reliable. That is until I installed the cooler and nothing but problems! From consistent flame outs to completley out of tune, I finally got a good temp and blew a glow plug! Took it off and it runs like a charm!!! Does anyone have experiance or thoughts on these coolers? Are they really worth anything, or just a headache?
Thank you for your opinions and advise in advance!!!
gixxerman is offline   Reply With Quote
Old 08-25-2009, 08:33 PM   #2
pinky2252s's Avatar
Send a message via AIM to pinky2252s Send a message via MSN to pinky2252s
They really dont do squat. You most likely have an air leak
Procrastinators Unite!.....Tomorrow
Team Terribles
pinky2252s is offline   Reply With Quote
Old 08-25-2009, 10:09 PM   #3
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I'm gonna have to disagree. I run with the op, and have been running the gas cooler longer than he has and been battling a bitchy engine. Not total dog shit, flaming out, but I felt I couldnt rely on it when I needed it. After his experience, I took mine off. I richened it 1 hour to be safe. My temps came in consistently 10 degrees higher, but I had 0 flame outs that race day. I also had switched to Odonell plugs, so I cant say for sure, but the gas cooler is staying off for now!
rallyebmx is offline   Reply With Quote
Old 08-26-2009, 01:57 AM   #4
aaron joy's Avatar
Trader Rating: 16 (94%+)
I have been running a RB cooler for 2 months now without a hitch on my RB C6. Can't really say if I got any more runtime as I didn't check before and after. Sounds more like a air leak as the other fellow mentioned.
aaron joy is offline   Reply With Quote
Old 08-26-2009, 06:35 AM   #5
I don't know exactly what you guys are talking about but it sounds like it may be something to cool your pipe? If that's the case then I would chuck that thing in the trash. From my experience with 2 strokes snowmobiles and bikes you want your pipe to be good and hot to produce maximum power. Cooling it is definitely a bad thing.
AsSc8 is offline   Reply With Quote
Old 08-26-2009, 06:42 AM   #6
Trader Rating: 52 (100%+)
actually the idea is to cool the fuel before it gets to the engine.... basically cooling the air that pressurizes the tank therefore cooling the fuel to the motor....either way I know in onroad they have been using them for a while,
but also they tune the motors on the brink of destruction
I like this thread, I am curious to see what the majority finds.. I have never run one so I cant say but I am still curious
Mo Denton-www.mnkraceway.com
Team Losi
Proline,-Redrock Hobbies-,VP Powermaster fuel,Darkside Designs,Speedy Bills!
fast for an old guy
Mo Denton is offline   Reply With Quote
Old 08-26-2009, 06:45 AM   #7
Oh ok I see. I should have looked it up to see what it was all about before posting.
Old 08-26-2009, 06:52 AM   #8
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i have been using one for over a year with NO problems....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 08-26-2009, 07:00 AM   #9
So what is the benifit to cooling your fuel?
Old 08-26-2009, 07:08 AM   #10
jpz_67's Avatar
Trader Rating: 56 (100%+)
I dont see how people could be having any adverse effects from the exhaust cooler? It is simply a cooling chamber run in the pressure line. The only possibility would be if the cooler had an air leak and that would cause some issues. I actually took the fittings off and put loctite on the threads in an effort to prevent this. I had no issues and in my testing I have netted an extra 20-40 seconds runtime. It may not seem like much but in racing every bit counts.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 08-26-2009, 07:24 AM   #11
its suppose to add runtime
Team Losi
fast for an old guy
Old 08-26-2009, 07:38 AM   #12
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I purpose of the exhaust line cooler is to cool the pressure gases entering the the tank from the pipe. This prevents the fuel in the tank from turning into non-useable vapors, leaving more fuel in liquid form when getting close to empty. This liquid fuel that would evaporate otherwise is what adds a bit more run time. Now, if you run your engines fairly rich, you will not see any benefits. This cooler works only on full hot race tuned motors that are dumping heat and vaporizing fuel (this is the mist you see in low tanks when refuelling) in the tank when the level is low.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-26-2009, 07:44 AM   #13
thats and awesome explanation...
only question is would that be hot motor race condition like the 260 range or hot racing conditions like outside temps?? just curious if it would make a difference running race tuned motors in a cold indoor track..
thanks
Team Losi
fast for an old guy
Old 08-26-2009, 07:46 AM   #14
Trader Rating: 32 (100%+)
hotter air means more of your nitro evaporating. less nitro methane.
I'd never trust an o-ring in that situation. use thread sealant.
i'm surprised someone hasn't come up with a heat pipe based fuel tank cooler.
Z01B | Xerun 150A 2000kv | Hitec | Desire-power 6S LiPo
Z01T | Tekin RX8 1700kv | Hitec | Desire-power 6S LiPo
Support your LHS, Al's Hobby, Elmhurst
devilchrist is offline   Reply With Quote
Old 08-26-2009, 07:46 AM   #15
Lonestar's Avatar
I've ran mine for about a month now. I can't say for sure I've noticed better run times (I'd have to do full, clean runs to guarantee that, as I don't expect more than a few seconds of additional non-vaporized fuel), but there sure are less fumes in the tank when you've reached the bottom of it. If only to make refueling easier, this is worth it. Plus it looks cool
there's no way this device can change the tune of an engine to the level described above - all it's doing is lengthening the pressure line by a couple of inch, and performing as a radiator on that length. the issue with the tune is elsewhere.
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
ALTOONA RACEWAY FORUM Ed237 Track Locator Forum 9108 06-28-2011 05:10 PM
Novarossi exhaust gas cooler 3600 PROVK Nitro On-Road 94 09-03-2009 11:03 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
