Old 08-25-2009, 02:54 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Why is this happening?
Hey guys, today when i started my v spec on my box i noticed something strange. Actually i dont know if its normal or if something is wrong. When i gave my engine throttle while the buggy was still on the starter box, the wheels continuously spun very fast. And there was a noise to it as well. Im not sure if maybe i didnt tighten the clutch bell onto the crankshaft right enough or what. Here is an example of what my buggy is not doing:
http://www.youtube.com/watch?v=qDC1CIQcVaA
When this person gives their engine throttle, they slowly come to a stop. But mine continue to spin. Any ideas?
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-25-2009, 03:03 PM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
Call me tonight, we will take care of it.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 08-25-2009, 03:04 PM   #3
jhipps835's Avatar
Will you still be able to help me out even though i dont have the engine right now?
Old 08-25-2009, 03:05 PM   #4
jhipps835's Avatar
Here is another one:
http://www.youtube.com/watch?v=i8IzRWlDX0U
See how he gets the speed up but the tires eventually slow down, thats definitely not what my buggy does.
Old 08-25-2009, 03:09 PM   #5
You don't have a motor? I can listen over the phone to help ya.
Old 08-25-2009, 03:11 PM   #6
jhipps835's Avatar
No. I have a motor on the way from being broken in. This was happening with my old motor but i no longer have that.
Old 08-25-2009, 03:15 PM   #7
Well it could be your bottom end is fat. If your just saying the idle wont drop right away. The wining noise could be bad bearing in the clutch. If you don't have it anymore I wouldn't worry about it.
Old 08-25-2009, 03:20 PM   #8
jhipps835's Avatar
It was also doing it at leisure hours. When i came down the straight and let off the throttle going into the first turn it made the whining noise. So should i get new clutch bearings or since i got the new engine it will be fine?
Old 08-25-2009, 03:25 PM   #9
I would change the bearings, they are only a buck for one. I change the bearings every weekend. I also race twice a week though. Also put a rubber band around the carb so it closes when you get off the throttle. I have seen some guys were it hangs open just a little. Then it close when the brake is used.
Old 08-25-2009, 03:27 PM   #10
jhipps835's Avatar
Okay i had a rubberband around the carb already but guess it wasnt strong enough.
Old 08-25-2009, 03:29 PM   #11
PM sent.
Old 08-25-2009, 03:30 PM   #12
coviello's Avatar
try leaning your bottom end a hair. replace the clutck bearings and the springs. youll be in good shape
coviello is offline   Reply With Quote
Old 08-25-2009, 03:44 PM   #13
xlgraphicspro's Avatar
am i the only one who has a problem with the fact that your asking a question about a motor you don't have any more?
and your problem sounds clutch related. weak clutch springs can cause your clutch shoes to grab at idle speeds. also your idle gap could be too big and that would cause your engine to idle too fast
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 08-25-2009, 03:55 PM   #14
jhipps835's Avatar
Why is there a problem that i dont have the engine anymore? Its still going to happen if its the clutch not the engine. Thats what you just said to fix so i dont get why you came in here saying there is a problem?
Old 08-25-2009, 03:58 PM   #15
Few things come to mind:
Will the engine idle at all without the wheels spinning?
When off, will the clutch bell spin without moving the flywheel? (If the flywheel spins either your clutch bearings are gone or your clutch nut backed off.)
If it's tune related, try to lean your bottom end about 6 hours and lower the idle about 5-6 hours. It's very common for people to have a very rich bottom end and have the idle high to compensate. When this is happening then when you let off the gas it will stay 'up on pipe' and have a 'run-on' feel to it.
Hope something here helps ya!
2010 is going to ROCK!! Thanks to my support system!!
-Tamiya -Alpha Plus Engines -Byrons Race Fuel
-R/C Pro Products -AKA Tires KO Propo
-Kal-Gard -TnT-Fx -TKO Bearings -Track Star
-Pyrographix Paints -Ballistic Batteries
TRCRacer24 is offline   Reply With Quote
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 03:36 PM
Slash vs SC10 todb Electric Off-Road 119 11-11-2009 05:18 PM
ESC forum Taz_S Electric On-Road 628 08-15-2009 08:59 PM
Team 1 R/C Magnet Zappers & Meters Kevin R/C Items: For Sale/Trade 10 12-03-2001 07:08 PM
OK, what happened? Speedo R/C Tech Site Forum 45 09-04-2001 06:18 PM
