Old 08-24-2009, 04:26 PM   #1
DNO
DNO's Avatar
Talking O'donnell Z01T setup
Looking for some help with a basic Z01T setup, primarily diffs oil and droop but all is appriciated. I have no starting point and O'donnell doesn't have one either. I'm currently running 7K front, 20K ctr, 5k rear with light swaybars, doesn't seem to be the right combo. Running a JPX .28 w/ a JP1 pipe. The local tracks are fairly short with tight turns, traction is loose.
DNO is offline   Reply With Quote
Old 08-24-2009, 05:09 PM   #2
Trader Rating: 47 (100%+)
do you have access to a fax i can fax you some of my setups
David,Courtney and Jacob Alfree
BYRON'S FUEL
PIGPENRC is offline   Reply With Quote
Old 08-24-2009, 05:27 PM   #3
DNO
DNO's Avatar
Unfortunetly no fax we'll have to do this the old fashioned way, through this thread
Old 08-24-2009, 05:36 PM   #4
Troy Pinkston's Avatar
email me at troy.pinkston AT gmail.com
I can send you some in the AM. They are on my other computer.
Troy Pinkston is offline   Reply With Quote
Old 08-24-2009, 05:58 PM   #5
DNO
DNO's Avatar
Thanks I'll do that
Old 08-25-2009, 10:12 AM   #6
Don, you got mail. I sent you 3 PDF's.
Old 08-25-2009, 11:07 AM   #7
We ran 10-15-2 diff oils with light sway bar on front and the heaviest one you can find for the rear. Silver ft springs yellow back, rear camber link inside middle on tower. Rear ride height level bones ft slightly below level and full droop.
donrod is offline   Reply With Quote
Old 08-25-2009, 03:58 PM   #8
DNO
DNO's Avatar
How did the setup work and for what size track? I'm getting serious front tire balloning and rear weight transfer It also comes out of a corner with the rear wanting to come around like a 360
Old 08-25-2009, 04:04 PM   #9
chris c's Avatar
Trader Rating: 60 (100%+)
front tire balloning is to low of a center diff weight oil. Try 20-30k in the center
Run the hubs foward and lower the rear camber link to the lowest hole on the tower. Try 5 in the rear also I run 10-15-5 in mine with a neg 30percent expo seems to help.
Also you could go with 2 alum and 1 carbon shoe. With a .28 and a jp-1 u have a lot of bottom end....
If you can make it I can break it
chris c is offline   Reply With Quote
Old 08-26-2009, 09:42 AM   #10
DNO
DNO's Avatar
Thanks for the help I'll give it a shot.
Odonnell Buggy!!! Brad S. Nitro Off-Road 9373 06-03-2016 10:45 AM
O'Donnell Z01-T Arena Truck Jon Carlson Nitro Off-Road 1320 04-20-2015 06:27 PM
Odonnell Z01T nitroal Nitro Off-Road 16 12-31-2008 06:31 AM
