Old 08-24-2009, 01:32 PM   #1
sand viper's Avatar
Send a message via MSN to sand viper
Default RC10gt NO GO!
Hello my name is ryan and i aquired a rc10 gt last year around the middle of the summer and it ran like a dream. I was running traxxas %20 fuel in it, and maintenced it offen. Before i put it away for the year i took it apart and cleaned it up nice. I replaced all the old fuel tubing and redid the shocks. When the time came again this spring when i was able to drive it i attempted to start it but it wont even fire. I got it to fire once after continuely swapping out glow plugs and turning over the engine. I charged the glow plug igniter up to a fully charge and it still wont start. I can see gas going into the carbuerator as its traveling throught the fuel line but its still a no go. I was just wondering what could cause it not to start? Bad fuel? wrong fuel tubing? air leak perhaps? It fired only once but once i applied a little throttle just to idle it up it quit! Can someone please help me out!!!!
sand viper is offline   Reply With Quote
Old 08-24-2009, 01:53 PM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
How old is the fuel? How old is your igniter, does it have a meter? Also Traxxas fuel is junk!
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 08-24-2009, 08:47 PM   #3
Test the glow ignighter on the glow plug and make the glow ignighter is working. Some times the ignighter gets dirty and does not light plug as well.
bigde2001 is offline   Reply With Quote
Old 08-25-2009, 12:50 AM   #4
if igniter works, glow plugs are good, fuel is flowing freely,etc...its definitely bad fuel if its really old
In3g_z33 is offline   Reply With Quote
Old 09-19-2010, 04:53 PM   #5
gt fast's Avatar
listen to these guys, fuel is only good for so long yea it will still burn but it needs to be really hot to run these little engines. try to hold one finger over the end of your pipe, the little part where the exhaust comes out and try starting it, like if your pull start do about 5 pulls then let go then 5 pulls without it blocked, it helps build uip fuel in chamber then maybe youll have some luck.
gt fast is offline   Reply With Quote
Old 09-19-2010, 06:44 PM   #6
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
i was in a pinch at the track ran out of fuel and cut practice short but i had a little traxxas fuel i used for cleaningout motors used that truck wouldnt start and the fuel wasnt bad once i got more byrons it started right up
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 09-19-2010, 07:04 PM   #7
gt fast's Avatar
yea man and traxxas fuel believe it or not is really high in oils. i run torco which is a knock off and ive never had a problem with it. traxxas was used for one quart on my car and everytime i went to start it i had to do several pulls. and at that it ran really lean all the time no matter how much i adjusted carb. but with other fuels i can pull 3 times max and engine is ready to roll. if youve got a old engine around you can actually run part diesel, and part 2 stoke oil. try it on a older motor just in case most people dont know these engines are diesel. it works
Carbon Fiber Car/Truck Stands Carbonman R/C Items: For Sale/Trade 98 04-06-2008 04:03 AM
For Sale or Trade Garage sale, mostly older.... RC10GT, Trinity 1/12... LOSI i1justin R/C Items: For Sale/Trade 41 03-16-2008 08:05 AM
WTS: Transponder, Radio, Parts, Tires, Motor Astomore R/C Items: For Sale/Trade 9 06-07-2007 02:13 PM
RC10GT Roller and Dynamite bump box FS wes95_z28 R/C Items: For Sale/Trade 8 05-04-2007 06:09 AM
RC10GT Fantom FR12 Starter Box derricklong38 R/C Items: For Sale/Trade 8 10-09-2006 01:59 PM
