Old 08-24-2009, 05:01 AM   #1
Default measuring carb slide opening?
Is there a way to measure the 1 mm for the carb slide when its at idle, or does everybody just eyeball it? I noticed on my trx 2.5 that I can back the idle screw almost all the way out and the it still idles fine. Is the slide supposed to close all the way or is there a internal stop? I can adjust the idle up ok, but it will only go down so far.
cassidy is offline   Reply With Quote
Old 08-24-2009, 05:23 AM   #2
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
just eyeball it
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
Old 08-24-2009, 11:30 AM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
you can make a feeler gauge with an old credit card
if you cant back it down, there is something wrong
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 08-24-2009, 08:51 PM   #4
If you trim is not adjusted right it wont allow the carb to close when you turn the idle down.
bigde2001 is offline   Reply With Quote
Old 08-24-2009, 09:29 PM   #5
I use drill bits to measure carb openings & pre fer to tune needles to match whatever the MFG says the opening should be set at give or take a hair.
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 08-24-2009, 09:56 PM   #6
spura's Avatar
Yap, I always use drill bits, you should get in hardware stores pretty cheap
Just take out venturi, close carb and measure, and make sure that you have properly adjusted link between carb and servo, because sometimes, if it not correct after turning on power it will move out and you will get bigger gap than you made
spura is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
