Old 08-22-2009, 09:21 PM   #1
portyansky's Avatar
Trader Rating: 54 (100%+)
Default OS Speed Tuned
Ive just acquired (on its way) a just broke in OS Speed Tuned for a pretty good deal (Guy getting out). I think its the 1st generation Speed, the head looks like its flat black with red writing. What are the pros and cons. I have always ran Vspecs and no other engine will go into my rides but OS brands, so I figured this would be a good back up motor. I have a race im going to next Sat and was wondering if this engine is better suited for technical tracks or big tracks? I think I remember reading somewhere that the speeds just had a smoother power band, but lacked the agressive Vspec snap.
Any input would be great.
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Old 08-22-2009, 09:27 PM   #2
The speed ou picked up is a first gen speed with the magnesium head. The magnesium is a bit lighter than aluminum and sheds heat more quickly. I also read somewhere the the port timing on this speed version may be a bit different than the standard speed motor due to the head. I have not run a mag head speed. I run the aluminum ones and as you know they are excellent motors.
HB D8T with BCE Chassis, ACE Shock towers and motor mounts, M2C Rear Suspension system, KH front steering plate and chassis braces, Lunsford Ti-turnbuckles & hinge pins, OS Speed motor, Hitec 5995TG steering, Futaba 9351 throttle/brake, OS 2060 pipe, and J concepts Punisher Body.
HB D8: CEO Mods Novarossi P5K with JP4 tuned pipe, JR 9000T steering, JR 8800T throttle.
gotspeed_2000 is offline   Reply With Quote
Old 08-23-2009, 02:54 PM   #3
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Thumbs up os speed
i run one and it great i run with a 5.5 restrictor to get the fuel mileage up its good for the big open track with sweeping turns .i have not tried to run on a small tight tech type of track ,i usually run the standard blue head v-spec for better snap out of the turn
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 08-23-2009, 03:34 PM   #4
portyansky's Avatar
thanks. the bigger restrictor should give me more torque punch, right?
Team Hitec
Old 08-23-2009, 05:36 PM   #5
im runnin the 7 in my speed with good smooth power.
im gonna shelve mine this winter for complete rebuild and im gonna try out a reg v-spec in my buggy
ive got around 7 gallons on my speed and have only replaced the front and main bearing. and still runs great. i usually pull it apart every gallon at this point for an inspection of rod and bearings. still decent pinch
rc-pro racing in gloucester va/TEAM TERRIBLES
ST-RR/8ight 2.0
osspeed,ebmods pipe,trinity platinum 30%,dx3r
crawldad91 is offline   Reply With Quote
Old 08-23-2009, 07:14 PM   #6
blade954's Avatar
Trader Rating: 23 (100%+)
I found the smaller restrictor will give you a "snappy" feel out of the corner and smooths the power up but the power curve falls off very quickly. We generally make a decision when we see the track, and then pick a insert to start with so we can generally match power with fuel consumption for the track.
blade954 is offline   Reply With Quote
Old 08-25-2009, 10:54 AM   #7
portyansky's Avatar
Good stuff, it should be here tomorrow. Just in time for Saturdays race.
Team Hitec
LOSI 8IGHT with OS SPEED tuned .21 nuttynative R/C Items: For Sale/Trade 33 02-06-2009 10:18 AM
OS Speed tuned V-spec juicenos1 R/C Items: For Sale/Trade 8 10-22-2008 01:15 PM
F/S Jammin CRT.5 , OS speed tuned 12TZ yle00984 R/C Items: For Sale/Trade 25 11-08-2007 02:58 PM
