Old 08-21-2009, 06:09 PM   #1
jhipps835's Avatar
Trader Rating: 13 (88%+)
Default Is my V Spec rod ruined?
Hey guys would you be able to tell me if my v spec rod is ruined by this video. There seems to be some slop in the connecting rod.
EDIT: Nevermind just going to buy a new rod. Thanks
Losi 8ight 2.0 - O.S V-Spec - Futaba - AKA - M8 - Spektrum - Byrons 20%
jhipps835 is offline   Reply With Quote
Old 08-21-2009, 06:18 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
If you have to even ask that question, replace it. Cheap insurance.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-21-2009, 06:18 PM   #3
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
From the sound, it sounds like you have the same problem that a fellow racer encountered with his. It was suspected that the hole in the connecting rod was wallowed out but upon further inspection, it turned out to be the conrod pin on the crank was worn...
K_B is offline   Reply With Quote
Old 08-21-2009, 06:26 PM   #4
Trader Rating: 47 (100%+)
Your video is nothing but a blur. But if that slapping
noise is coming from the bottom of the rod. Then,
yes it is shot. You may want to pull the crank and
mike the con rod pin also. It may be hammered too.
rageworks is offline   Reply With Quote
Old 08-21-2009, 06:31 PM   #5
jhipps835's Avatar
Thanks guys
