Old 08-20-2009, 07:19 PM   #1
sokar's Avatar
Default Engine acting funny.
After tearing down my engine and discovering it lost some compression, I put it back together and started it up. If I leave the igniter in, it runs OK. When I take it out, the engine bogs, warbles, pops, gargles, spits, smokes, etc. but only when accelerating and deccelerating. I've been trying to tune it but haven't had much luck. I replaced the glow plug not too long ago (about maybe 1/4 of a gallon run through the current glow plug). What could be causing this, and how could I fix it?
Team Terribles
God Hates Faqs (frequently asked questions)
sokar is offline   Reply With Quote
Old 08-20-2009, 07:23 PM   #2
mudboger07's Avatar
Have ya check to se if you put the piston in backwards? It is possbile, and wil run but not very good...
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 08-20-2009, 07:26 PM   #3
sokar's Avatar
I took everything except the piston and sleeve out. I left those alone.
Team Terribles
Old 08-20-2009, 07:26 PM   #4
coviello's Avatar
new shims and seal that bad boy up.
coviello is offline   Reply With Quote
Old 08-20-2009, 07:40 PM   #5
mudboger07's Avatar
Like covielle said seal the back plate and card with silicon and id install a new plug then prob recheck your tune.......
Ken
Old 08-20-2009, 07:46 PM   #6
sokar's Avatar
Oh, it also smokes like crazy. There's tons of blue smoke coming from all around the engine
Team Terribles
Old 08-20-2009, 07:53 PM   #7
HaulinBass's Avatar
replace the plug if that doesnt help lean the engine out, no engine will run rich with an airleak its physiclly impossible.
HaulinBass is offline   Reply With Quote
Old 08-20-2009, 07:53 PM   #8
mudboger07's Avatar
again after sealing the motor, you might want to check the ext gaskets, it could also be the bearings......
Ken
Old 08-20-2009, 08:06 PM   #9
sokar's Avatar
BTW I bent a shim but I didn't think it mattered because it is being squished by the cylander.
Team Terribles
Old 08-21-2009, 06:32 AM   #10
Zerodefect's Avatar
It matters, if it it was bent enough, then the head might not be able to squish it flat. metal stretches when its bent. When you straighten it, it deosn't go back to where it was very well, especially a ring or round piece.
Zerodefect is offline   Reply With Quote
Old 09-03-2009, 09:47 AM   #11
This doesn't make sense to me. If an engine isn't getting as much air as it should, wouldn't there be more fuel than needed, therefore it's rich ? Or do you mean "rich" as in the amount of fuel it'd need if the air was right ?
Jeimuzu is offline   Reply With Quote
Old 09-04-2009, 11:06 AM   #12
HaulinBass's Avatar
an engine that is sucking air from somewhere else other than the carb, cannot run rich. the fuel and air go through the carb at a certain mix if there is air entering the engine anywhere else than more air is getting added to that mix and its being carborated again.
Think about it like sucking a pool of water up with a water pump if you put a huge hole in the suction hose its going to suck a bunch of air instead of water.
Old 09-04-2009, 12:43 PM   #13
Oh I was thinking that an airleak let air out, not extra air being sucked in.
Houstons Engine Service H.E.S. houston Offroad Nitro Engine Forum 8821 06-17-2017 12:29 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Who can I ship my motor to to get a failure diagnosed? Lonestar Nitro Off-Road 30 07-16-2009 08:12 AM
vspec unbeatable?!?! liteumup387 Nitro Off-Road 36 06-14-2009 06:13 AM
What does it do when you pinch an engine???? Help halfman Nitro Off-Road 14 03-21-2009 07:38 AM
I need advice...PLEASE HELP!!! luketob Nitro On-Road 10 08-15-2003 01:40 AM
